How to sync to /flash and not /sd?
  • I'm using atom and the Pycom extension to work with the xxPy's. When coding without an inserted sd-card the syncing goes to the /flash filesystem, however when inserting a sd-card the syncing start writing towards the /sd instead.
    Is there a way to force the use of the /flash or must I remove the sd-card every time?
  • Hi @rolandvs, thanks for reporting this. Atom is not really aware of the /flash or /sd directories, but uploads the code to where the REPL is running from. It could be that inserting the SD card makes the repl start from the /sd folder. I don't really have a solution to it right now, but I'll look in to it together with embedded.
