Docs Update Deep Sleep - Correction
Hi all,
Quick note to clear up some confusion regarding the Deep Sleep Shield. Previous to this post, the image and pinout document posted on the docs (https://docs.pycom.io/chapter/datasheets/boards/deepsleep.html) was actually rotated 180 degrees from how it should have been. This has now been corrected.
If you're trying to use the Shield, please ensure that the LED aligns with the white triangle on the Deep Sleep Shield and then plug your Pycom device into your expansion board.
If you're unsure, check the docs as they are now correct reference for how to do this!
Thanks!
Alex
