get_wake_status() with Deep Sleep shield
I'm trying to figure out the logic of the
get_wake_status()
function after going for a deep sleep or hard reset.I assume that according to the code of the deepsleep library, the wake value from the returned dictionary would be different depending on wether it's a boot from power on or after the timer has expired, right?
However, I always get a value of 16, no matter what.
Has anyone tested this functionality?
@rskoniec Thanks, it helped debugging. If I unplug the power completely it shows the POWER_ON_WAKE, but if I do a manual reset (button pressed) it says TIMER_WAKE. I reckon it's a bit confusing.
I couldn't see the values after connecting the USB and reconnecting to the console, so I assumed a manual reset would be treated as a POWER_ON_WAKE.
Did you try something like this?
from deepsleep import DeepSleep ds = DeepSleep() # get the wake reason and the value of the pins during wake up wake_s = ds.get_wake_status() print(wake_s) if wake_s['wake'] == deepsleep.PIN_WAKE: print("Pin wake up") elif wake_s['wake'] == deepsleep.TIMER_WAKE: print("Timer wake up") else: # deepsleep.POWER_ON_WAKE: print("Power ON reset")
https://docs.pycom.io/chapter/datasheets/boards/deepsleep/api.html
