LoPy/WiPy 2/ESP32 specs and performance
  • Some WiPy 2/LoPy specs and performance that it would be useful to know, theoretically and measured :
    • free RAM (depends on firmware version);
    • flash memory available for MicroPython user;
    • LoRa speed and range in real user cases;
    • WiFi speed and range in real user cases;
    • Bluetooth speed and range in real user cases.
    ESP32 (used by LoPy and WiPy 2) specs, theoretically and measured :
    • Xtensa LX6 performance, using some MicroPyton benchmark code;
    • ADC (12 bits, 16 ports, 8 channels) speed in ksamples/s;
    • DAC (10 bits, 2 ports, 2 channels) speed in ksamples/s.
    Topics about the same subject, in MicroPython forum :
    Free RAM on MicroPython boards
    Benchmark comparison of MicroPython boards
    ADC performance of MicroPython boards
  • With firmware v0.9.5.b1 (19/11/2016), the measured specs for :
    • WiPy 2.0 : free RAM 79152 bytes; 499 KB of free internal "/flash";
    • LoPy : free RAM 79152 bytes; 497 KB of free internal "/flash".
    With firmware v0.9.6.b1 (25/11/2016), the measured specs for :
    • WiPy 2.0 : free RAM 79152 bytes; 498 KB of free internal "/flash"..
    • LoPy : free RAM 79152 bytes; 497 KB of free internal "/flash"..
    So the free RAM wasn't changed since v0.9.3.b2.
    Updated the benchmarks below with v0.9.5.b1 and v0.9.6.b1 releases.
  • ADC performance tests of MicroPython boards :
    1. 'ADC_timedtimer_Pyboard.py' as only Pyboard has "ADC.read.timed()" method to ADC read burst into buffer in high speed. Test with 20 thousand readings, mean speed in ksample/s :
    • Pyboard v1.1 (12 bits ADC) with MicroPython v1.8.6 : 1,604;
    • Pyboard Lite v1.0 (12 bits) with MicroPython v1.8.6 : 899.6;
    1. 'ADC_loop' (download here for different boards) with 20 thousand readings, mean speed in ksample/s :
    • Pyboard v1.1 (12 bits ADC) with MicroPython v1.8.6 : 34.9;
    • Pyboard Lite v1.0 (12 bits) with MicroPython v1.8.6 : 20.1;
    • WiPy 1.0 (12 bits) with MicroPython v1.8.2-103 : 62.5;
    • ESP8266 (10 bits) with MicroPython v1.8.6-7 : 5.44 (80 MHz) / 7.34 (160 MHz);
    • BBC Micro:bit (10 bits) with MicroPython v1.7.9 : 6.51;
    • LoPy (12* bits) with MicroPython 0.9.6.b1 : 21.2.
    • WiPy2 (12* bits) with MicroPython 0.9.6.b1 : 21.3.
    • Teensy 3.2 (16 bits) with MicroPython v1.8.6 : 59.6;
    • Teensy 3.5 (16 bits) with MicroPython v1.8.6 : 62.3;
    • Teensy 3.6 (16 bits) with MicroPython v1.8.6 : 107.
    (*) : this firmware is limiting the ADC to only 10 bits, 0-1V.
    For example, "ADC_loop_LoPyWiPy2.py" :
    # Reads the LoPy/WiPy2 ADC and measures the time and speed to read 20000 samples.
    def ADCloopBenchmark():
        adc = machine.ADC(0)
        adcread = adc.channel(pin='P13')
        t1 = time.ticks_ms()
        for i in range(20000):
            val = adcread()
        t2 = time.ticks_ms()
        print("20000 ADC readings done after %u ms." %(t2-t1))
        print("Mean time for each ADC reading = %15.13f us" % ((t2-t1)/20.0))
        print("ADC reading = %15.13f ksamples/s" % ((20*10**3)/(t2-t1)))
    ADCloopBenchmark()
    Pyboard (v1.1) is the champion MicroPython board, with 1.6 Msamples/s for ADC burst reading ! Followed by Pyboard Lite with 0.9 Msamples/s in this mode.
    For continuously ADC reading inside a loop, Teensy board and WiPy 1.0 are the fastest, followed by the Pyboard's. BBC Micro:bit surprised me, as its MCU is nRF51822 with ARM Cortex-M0 @ 16MHz.
    With the last firmware releases, LoPy and WiPy 2 ADC is a lot faster than before.
    'ADC_loop', mean speed in ksample/s :
    • LoPy with MicroPython 0.9.4.b1 : 3.65;
    • WiPy 2 with MicroPython 0.9.4.b1 : 13.8;
    • LoPy with MicroPython 0.9.5.b1 : 13.0;
    • WiPy 2 with MicroPython 0.9.5.b1 : 12.3;
    • LoPy with MicroPython 0.9.6.b1 : 21.2;
    • WiPy 2 with MicroPython 0.9.6.b1 : 21.3.
    Performance improvements for LoPy and WiPy 2 are expected with new firmware releases, including in ADC reading speed.
    (27/11/2016) : ADC benchmarks for releases 0.9.5.b1 and 0.9.6.b1.
  • @betabrain Good question. But in LoPy Kickstarter project, I don't see any mention about native or viper decorator.
    The MicroPython for ESP8266 project lists the implementation of @micropython.native, @micropython.viper and @micropython.asm_xtensa decorators, but not yet implemented.
  • When will MicroPython get native/viper support for ESP32? Obviously, this would make the benchmarks a lot more interesting.
  • Some benchmark comparison of MicroPython boards :
    1. pystone_lomem (with '%g' changed to '%u' in lines 69 and 71 to be compatible with WiPy 1.0, download here), in pystones/second :
    • Pyboard v1.1 with MicroPython v1.8.6 : 1,754;
    • Pyboard Lite v1.0 with MicroPython v1.8.6 : 1,048;
    • WiPy 1.0 with MicroPython v1.8.2-103 : 659;
    • ESP8266 with MicroPython v1.8.6-7 : 223 (80 MHz) / 415 (160 MHz);
    • BBC Micro:bit with MicroPython v1.7.9 : not enough RAM to run;
    • LoPy with MicroPython 0.9.6.b1 : 829;
    • WiPy2 with MicroPython 0.9.6.b1 : 836;
    • Teensy 3.2 with MicroPython v1.8.6 : 846;
    • Teensy 3.5 with MicroPython v1.8.6 : 1086;
    • Teensy 3.6 with MicroPython v1.8.6 : 2212;
    1. PerformanceTest using 'time.ticks_ms' (download here versions with 'pyb.millis', 'time.ticks_ms' and 'microbit.running_time()'), in number of times in 10s :
    • Pyboard v1.1 with MicroPython v1.8.6, using 'pyb.millis' : 2,815,970 / 4,610,390 (native) / 8,771,699 (viper);
    • Pyboard v1.1 with MicroPython v1.8.6 : 2,783,122;
    • Pyboard Lite v1.0 with MicroPython v1.8.6, using 'pyb.millis' : 1,738,503 / 2,686,262 (native) / 5,392,659 (viper);
    • Pyboard Lite v1.0 with MicroPython v1.8.6 : 1,732,370;
    • WiPy 1.0 with MicroPython v1.8.2-103 : 918,031;
    • ESP8266 with MicroPython v1.8.6-7 : 171,145 (80 MHz) / 341,224 (160 MHz);
    • BBC Micro:bit with MicroPython v1.7.9 : 168,826;
    • LoPy with MicroPython 0.9.6.b1 : 651,394;
    • WiPy2 with MicroPython 0.9.6.b1 : 680,488;
    • Teensy 3.2 with MicroPython v1.8.6 : 1,041,445;
    • Teensy 3.5 with MicroPython v1.8.6 : 1,204,193
    • Teensy 3.2 with MicroPython v1.8.6 : 3,451,931;
    1. hsquare.py (type Ia supernova calculation with float point for 50,000 points), mean time for each calculation in us :
    • Pyboard v1.1 with MicroPython v1.8.6 : 83;
    • Pyboard Lite v1.0 with MicroPython v1.8.6 : 139;
    • WiPy 1.0 with MicroPython v1.8.2-103 : - (no float point support);
    • ESP8266 with MicroPython v1.8.6-7 : 460 (80 MHz) / 239 (160 MHz);
    • BBC Micro:bit with MicroPython v1.7.9 : 1,589;
    • LoPy with MicroPython 0.9.6.b1 : 107;
    • WiPy2 with MicroPython 0.9.6.b1 : 143;
    • Teensy 3.2 with MicroPython v1.8.6 : 278;
    • Teensy 3.5 with MicroPython v1.8.6 : 138
    • Teensy 3.2 with MicroPython v1.8.6 : 73.
    MicroPython release 0.9.6.b1 (for LoPy and WiPy 2) has default ESP32 frequency set as 160 MHz, instead of 80 MHz as before.
    With the last releases, LoPy and WiPy 2 are a lot faster than before :
    1. pystone_lomem, in pystones/second :
    • LoPy with MicroPython 0.9.4.b1 : 321;
    • WiPy 2 with MicroPython 0.9.4.b1 : 404;
    • LoPy with MicroPython 0.9.5.b1 : 354;
    • WiPy 2 with MicroPython 0.9.5.b1 : 388;
    • WiPy 2 with MicroPython 0.9.6.b1 : 836;
    1. PerformanceTest, in number of times in 10s :
    • LoPy with MicroPython 0.9.4.b1 : 91,810;
    • WiPy 2 with MicroPython 0.9.4.b1 : 281,083;
    • LoPy with MicroPython 0.9.5.b1 : 293,032;
    • WiPy 2 with MicroPython 0.9.5.b1 : 260,478;
    • WiPy 2 with MicroPython 0.9.6.b1 : 680,488;
    1. hsquare, mean time for each calculation in us :
    • LoPy with MicroPython 0.9.4.b1 : 542;
    • WiPy 2 with MicroPython 0.9.4.b1 : 184;
    • LoPy with MicroPython 0.9.5.b1 : 167;
    • WiPy 2 with MicroPython 0.9.5.b1 : 191;
    • LoPy with MicroPython 0.9.6.b1 : 107.
    • WiPy 2 with MicroPython 0.9.6.b1 : 142.
    Performance improvements for LoPy and WiPy 2 are expected with new firmware releases.
    (20/11/2016 : added BBC Micro:bit)
    (21/11/2016 : added Teensy 3.x)
    (27/11/2016 : updated LoPy and WiPy 2 with firmware 0.9.6.b1)
  • With firmware v0.9.4.b1 (14/11/2016), the measured specs for :
    • LoPy : free RAM 79152 bytes; 496 KB of free internal "/flash".
    So the free RAM wasn't changed from v0.9.3.b2.
  • With firmware v0.9.3.b2 (05/11/2016), the measured specs for :
    • LoPy : free RAM 79152 bytes; 498 KB of free internal "/flash".
    So the free RAM increased 8KB.
  • Measured specs with firmware v0.9.2.b2 (28/10/2016) :
    • WiPy 2.0 : free RAM 71152 bytes; 498 KB of free internal "/flash".
    • LoPy : free RAM 71152 bytes; 498 KB of free internal "/flash".
    Free RAM was measured with :
    import gc
    gc.collect()
    gc.mem_free()
    Is there any command to measure the free internal flash space ? I've measured by uploading files and summing up the sizes.
