[SOLVED] LoPy not receiving acknowledgement downlinks from network server
  • Hi,
    Is there a particular setting required on the LoPy, when sending an uplink, to request that the LoRa network server sends back an acknowledgement downlink to the LoPy?
    I'm asking, because I don't get any when running the ABP example in the Pycom Docs.
    The server is receiving the uplinks as expected, but it just doesn't send anything back for the LoPy.
    I have used the mDot (by MultiTech) with the same network server and acknowledgement downlinks are being sent as expected.
    Thank you very much for your time and support. A+ :)
    Frank
  • @jmarcelino
    As you suspected, I was implicitly using:
    s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, False)
    So I explicitly added
    to my script, and now the network server returns a downlink, and I am able to access the [LoRa instance].stats().
    Thank you very much for taking the time to help me out. A+ :)
    Frank
  • This post is deleted!
  • By acknowledgement packets do you mean you're sending confirmed uplinks set with:
    s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, False)?
    If so I don't think you get an explicit downlink, what you should get is a LoRa.TX_PACKET_EVENT if the ack was received - you can then trigger your code based on this event with
    lora.callback(trigger=(LoRa.TX_PACKET_EVENT), handler=your_lora_callback_function)
