Failed to connect to ESP32: Invalid head of packet.('\x08')
hi all,
I am new users of Pycon LoPy i want to test my board.
I use pycon hello_world in C at this https://github.com/pycom/pycom-esp-idf.
when i flash then with eclipse i have a mistake saying .
Connecting.....................................................A fatal error occurred: Failed to connect to ESP32: Invalid head of packet ('\x08')
make: *** [flash] Error 2
i don't know where is my problem.
I use mac os x.
Need help.
thanx
@nadvorvo For anyone having the same issue today, this solved it for me too
Finally thanks to @robert-hh problem was identified:
even it is V3.1 expansion board it was necessary to force Bootloader mode by connecting P2 to GND + pushing Reset
then everything was okYou can recognize being or not being in bootloader mode:
LED flashing in period aprox. 3 second ... not being in bootloader mode
LED off ... bootloader modeRegards, Vojtech
Hi @robert-hh,
sure Atom was terminated (no other app using this COM port)
@nadvorvo Did you terminate Atom with command-Q before uploading the firmware?
Hi @robert-hh, @Gijs
Thank you for prompt reply. The GPy is normally working with ATOM (python REPL is ok).Thank you in advance for your assistance.
Regards, Vojtech
@nadvorvo Can you get a REPL prompt if you connect with the board using screen or the like?
Thank you for your reply.I have tested both 115200/57600 Baud. Result is same:
Thanks a lot for writing back.
Regards, Vojtech
@nadvorvo try to lower the speec.
Hi everyone,
I hope you can help in this matter.
Regards, VojtechI am following this tutorial:
https://docs.pycom.io/updatefirmware/device/expansion board: V3.1
GPy V1.2
I am downgrading to version GPy-1.20.2.r1.tar.gzI do not connect a jumper cable or wire between G23 and GND (only for version 2.0)
LED blinks blue (GPy not in programing mode).It fails with message:
pycom failed to connect to esp32 invalid head of packet (\x08)
