    LoRa.ABP Downlink messages no receive
    lorattndownlingabp
    3 Posts 2 Posters 1.9k Views 3 Watching
      constantinos
      I have implemented a LoRa nanogateway with LoPy connected to TTN.
      I have also another LoPy (Node) transmitting data via this gateway.
      Whenever I create a downlink message via TTN I can see it in nanogateway but the message is never arrived at LoPy Node.
        jcaron
        You are aware that downlink messages are send only as a reply to an uplink? So you need to send an uplink to receive a previously queued downlink.
        Also, it would probably help if you shared your code.
          constantinos @jcaron
          @jcaron I know that you must perform an uplink in order to have a downlink.
          The strange thing is that the nanogateway makes the LoRa TX but nothing is received.
          Nano Gateway code
          """ LoPy Nano Gateway class """
          from network import WLAN
          from network import LoRa
          from machine import Timer
          from network import Server as tcpserver
          import os
          import binascii
          import json
          import errno
          import _thread
          PROTOCOL_VERSION = const(2)
          PUSH_DATA = const(0)
          PUSH_ACK = const(1)
          PULL_DATA = const(2)
          PULL_ACK = const(4)
          PULL_RESP = const(3)
          TX_ERR_NONE = "NONE"
          TX_ERR_TOO_LATE = "TOO_LATE"
          TX_ERR_TOO_EARLY = "TOO_EARLY"
          TX_ERR_COLLISION_PACKET = "COLLISION_PACKET"
          TX_ERR_COLLISION_BEACON = "COLLISION_BEACON"
          TX_ERR_TX_FREQ = "TX_FREQ"
          TX_ERR_TX_POWER = "TX_POWER"
          TX_ERR_GPS_UNLOCKED = "GPS_UNLOCKED"
          STAT_PK = {"stat": {"time": "", "lati": 0,
                              "long": 0, "alti": 0,
                              "rxnb": 0, "rxok": 0,
                              "rxfw": 0, "ackr": 100.0,
                              "dwnb": 0, "txnb": 0}}
          RX_PK = {"rxpk": [{"time": "", "tmst": 0,
                             "chan": 0, "rfch": 0,
                             "freq": 868.1, "stat": 1,
                             "modu": "LORA", "datr": "SF7BW125",
                             "codr": "4/5", "rssi": 0,
                             "lsnr": 0, "size": 0,
                             "data": ""}]}
          TX_ACK_PK = {"txpk_ack":{"error":""}}
          class NanoGateway:
              def __init__(self, id, frequency, datarate, ssid, password, server, port, ntp='pool.ntp.org', ntp_period=3600):
                  self.id = id
                  self.frequency = frequency
                  self.datarate = datarate
                  self.sf = self._dr_to_sf(datarate)
                  self.ssid = ssid
                  self.password = password
                  self.server = server
                  self.port = port
                  self.ntp = ntp
                  self.ntp_period = ntp_period
                  self.rxnb = 0
                  self.rxok = 0
                  self.rxfw = 0
                  self.dwnb = 0
                  self.txnb = 0
                  self.stat_alarm = None
                  self.pull_alarm = None
                  self.uplink_alarm = None
                  self.udp_lock = _thread.allocate_lock()
                  self.lora = None
                  self.lora_sock = None
              def start(self):
                  # Change WiFi to STA mode and connect
                  print("Starting nanogateway")
                  self.wlan = WLAN(mode=WLAN.STA)
                  self._connect_to_wifi()
                  # Get a time Sync
                  self.rtc = machine.RTC()
                  self.rtc.ntp_sync(self.ntp, update_period=self.ntp_period)
                  # Get the server IP and create an UDP socket
                  self.server_ip = socket.getaddrinfo(self.server, self.port)[0][-1]
                  print("Gateway IP:",self.server_ip)
                  self.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP)
                  self.sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
                  self.sock.setblocking(False)
                  # Push the first time immediatelly
                  self._push_data(self._make_stat_packet())
                  # Create the alarms
                  self.stat_alarm = Timer.Alarm(handler=lambda t: self._push_data(self._make_stat_packet()), s=60, periodic=True)
                  self.pull_alarm = Timer.Alarm(handler=lambda u: self._pull_data(), s=25, periodic=True)
                  # Start the UDP receive thread
                  _thread.start_new_thread(self._udp_thread, ())
                  # Initialize LoRa in LORA mode
                  self.lora = LoRa(mode=LoRa.LORA, frequency=self.frequency, bandwidth=LoRa.BW_125KHZ, sf=self.sf,
                                   preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True)
                  # Create a raw LoRa socket
                  self.lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
                  self.lora_sock.setblocking(False)
                  self.lora_tx_done = False
                  self.lora.callback(trigger=(LoRa.RX_PACKET_EVENT | LoRa.TX_PACKET_EVENT), handler=self._lora_cb)
                  print("Started")
              def stop(self):
                  # TODO: Check how to stop the NTP sync
                  # TODO: Create a cancel method for the alarm
                  # TODO: kill the UDP thread
                  self.sock.close()
              def _connect_to_wifi(self):
                  self.wlan.connect(self.ssid, auth=(None, self.password))
                  while not self.wlan.isconnected():
                      time.sleep(0.5)
                  print("WiFi connected!")
                  tserver=tcpserver()
                  tserver.deinit()
                  tserver.init(login=("nemet", "nemet.gr"), timeout=60)
              def _dr_to_sf(self, dr):
                  sf = dr[2:4]
                  if sf[1] not in '0123456789':
                      sf = sf[:1]
                  return int(sf)
              def _sf_to_dr(self, sf):
                  return self.datarate
              def _make_stat_packet(self):
                  now = self.rtc.now()
                  STAT_PK["stat"]["time"] = "%d-%02d-%02d %02d:%02d:%02d GMT" % (now[0], now[1], now[2], now[3], now[4], now[5])
                  STAT_PK["stat"]["rxnb"] = self.rxnb
                  STAT_PK["stat"]["rxok"] = self.rxok
                  STAT_PK["stat"]["rxfw"] = self.rxfw
                  STAT_PK["stat"]["dwnb"] = self.dwnb
                  STAT_PK["stat"]["txnb"] = self.txnb
                  return json.dumps(STAT_PK)
              def _make_node_packet(self, rx_data, rx_time, tmst, sf, rssi, snr):
                  RX_PK["rxpk"][0]["time"] = "%d-%02d-%02dT%02d:%02d:%02d.%dZ" % (rx_time[0], rx_time[1], rx_time[2], rx_time[3], rx_time[4], rx_time[5], rx_time[6])
                  RX_PK["rxpk"][0]["tmst"] = tmst
                  RX_PK["rxpk"][0]["datr"] = self._sf_to_dr(sf)
                  RX_PK["rxpk"][0]["rssi"] = rssi
                  RX_PK["rxpk"][0]["lsnr"] = float(snr)
                  RX_PK["rxpk"][0]["data"] = binascii.b2a_base64(rx_data)[:-1]
                  RX_PK["rxpk"][0]["size"] = len(rx_data)
                  return json.dumps(RX_PK)
              def _push_data(self, data):
                  token = os.urandom(2)
                  packet = bytes([PROTOCOL_VERSION]) + token + bytes([PUSH_DATA]) + binascii.unhexlify(self.id) + data
                  with self.udp_lock:
                      try:
                          self.sock.sendto(packet, self.server_ip)
                      except Exception:
                          print("PUSH exception")
              def _pull_data(self):
                  packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_DATA]) + binascii.unhexlify(self.id)
                  with self.udp_lock:
                      try:
                      except Exception:
                          print("PULL exception")
              def _ack_pull_rsp(self, token, error):
                  TX_ACK_PK["txpk_ack"]["error"] = error
                  resp = json.dumps(TX_ACK_PK)
                  packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_ACK]) + binascii.unhexlify(self.id) + resp
                  with self.udp_lock:
                      try:
                      except Exception:
                          print("PULL RSP ACK exception")
              def _lora_cb(self, lora):
                  events = lora.events()
                  if events & LoRa.RX_PACKET_EVENT:
                      self.rxnb += 1
                      self.rxok += 1
                      rx_data = self.lora_sock.recv(256)
                      print("LoRa_RX:",rx_data)
                      stats = lora.stats()
                      self._push_data(self._make_node_packet(rx_data, self.rtc.now(), stats.rx_timestamp, stats.sfrx, stats.rssi, stats.snr))
                      self.rxfw += 1
                  if events & LoRa.TX_PACKET_EVENT:
                      self.txnb += 1
                      lora.init(mode=LoRa.LORA, frequency=self.frequency, bandwidth=LoRa.BW_125KHZ,
                                sf=self.sf, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True)
              def _send_down_link(self, data, tmst, datarate, frequency):
                  self.lora.init(mode=LoRa.LORA, frequency=frequency, bandwidth=LoRa.BW_125KHZ,
                                 sf=self._dr_to_sf(datarate), preamble=8, coding_rate=LoRa.CODING_4_5,
                                 tx_iq=True)
                  while time.ticks_us() < tmst:
                      pass
                  print("LoRa_TX",data)
                  self.lora_sock.send(data)
              def _udp_thread(self):
                      try:
                          data, src = self.sock.recvfrom(1024)
                          _token = data[1:3]
                          _type = data[3]
                          if _type == PUSH_ACK:
                              print("Push ack")
                          elif _type == PULL_ACK:
                              print("Pull ack")
                          elif _type == PULL_RESP:
                              self.dwnb += 1
                              ack_error = TX_ERR_NONE
                              tx_pk = json.loads(data[4:])
                              tmst = tx_pk["txpk"]["tmst"]
                              t_us = tmst - time.ticks_us() - 5000
                              if t_us < 0:
                                  t_us += 0xFFFFFFFF
                              if t_us < 20000000:
                                  self.uplink_alarm = Timer.Alarm(handler=lambda x: self._send_down_link(binascii.a2b_base64(tx_pk["txpk"]["data"]),
        tx_pk["txpk"]["tmst"] - 10, tx_pk["txpk"]["datr"],
        int(tx_pk["txpk"]["freq"] * 1000000)), us=t_us)
                                  ack_error = TX_ERR_TOO_LATE
                                  print("Downlink timestamp error!, t_us:", t_us)
                              self._ack_pull_rsp(_token, ack_error)
                              print("Pull rsp")
                      except socket.timeout:
                          print("Socket Timeout")
                      except OSError as e:
                          if e.errno == errno.EAGAIN:
                              #print("UDP recv errno.EAGAIN")
                              pass
                              print("UDP recv OSError Exception")
                      except Exception:
                          print("UDP recv Exception")
                      # Wait before trying to receive again
                      time.sleep(0.025)
          Node code
          import binascii
          import struct
          # Initialize LoRa in LORAWAN mode.
          dev_addr = struct.unpack(">l", binascii.unhexlify('260110AD'.replace(' ','')))[0]
          nwk_swkey = binascii.unhexlify('2F8184207979F18CE1F64B6B74B75A99'.replace(' ',''))
          app_swkey = binascii.unhexlify('53A7AA9AFA94FEB1F859F76EF5E0BA4C'.replace(' ',''))
          # join a network using ABP (Activation By Personalization)
          # remove all the non-default channels
          for i in range(3, 16):
              lora.remove_channel(i)
          # set the 3 default channels to the same frequency
          lora.add_channel(0, frequency=868100000, dr_min=0, dr_max=5)
          lora.add_channel(1, frequency=868100000, dr_min=0, dr_max=5)
          lora.add_channel(2, frequency=868100000, dr_min=0, dr_max=5)
          # create a LoRa socket
          # set the LoRaWAN data rate
          # make the socket blocking
          s.setblocking(False)
          i = 1
              pycom.rgbled(0x100000)
              print("sending:",i,i % 255,"msg:",struct.pack('LB',i,i % 255))
              s.send(struct.pack('LB',i,i % 255))
              pycom.rgbled(0x001000)
              for k in range(29):
                  rx = s.recv(256)
                  if rx:
                      print("RX:",rx)
              i += 1
