    Lora network with two lopy and OTAA
    loralorawanotaa
    1 Posts 1 Posters 722 Views 2 Watching
      gus
      Is it possible to use two Lora, one as a node the other as a gateway (connected in wifi to my home router) and connect the node to the gateway using OTAA. (using Lorawan).
      edit: in the doc i see exemple with rawLora but none with loraWan
      Thank you for your help.
