Use external Bluetooth module on WiPy 2.0?
Because BLE is a bit slow for my need, can I connect an external bluetooth module to the WiPy? Will this be easy enough to work with?
Thank you!
@panos29
depend of external device.
But many are really easy to use. -
@livius thanks for the answer. Could you perhaps recommend any module in particular?
@panos29
i have used e.g. HC05
it is comunicating throught RX/TX i do not know if can be something simpler..
With your input, this post could be even better š
