NB-IoT Lora gateway
I was wondering if it would be possible/a good idea to use a FiPy to act as a LoRa gateway using NB-IoT to connect to internett while using LoRaWan for the nodes. What I want to avoid is having a full LoRa gateway and power it using solar and 3G for internett.
@sysfrog a real LoRaWAN gateway needs to support several channels at the same time, so if you want “real” LoRaWAN, which you could use any LoRaWAN device on, then no.
If on the other hand you control the devices, and can use a limited subset of LoRaWAN or even raw LoRa, then it’s probably possible.
