SSL socket fails with OSError: -30592
 Hello! I am trying to connect to a node.js server on a ZEIT instance, zeit.co. ZEIT handles the SSL through an nginx proxy ( I think ). My following code works when connecting to google but not the ZEIT server. I get a weird error code: Traceback (most recent call last): File "main.py", line 146, in networkThread File "main.py", line 54, in connectToService OSError: -30592line 54 is the ss.connect(...)line, Here is my connection code:def connectToService(): global socketQueue global serialQueue print("Creating Socket...") ss = socket.socket() print("Wrapping Socket...") ss = ssl.wrap_socket(ss) print("Connecting...") #this next line works #ss.connect(socket.getaddrinfo('www.google.com', 443)[0][-1]) #this line does not ss.connect(socket.getaddrinfo('thismeshserver-fhprkttlyv.now.sh', 443)[0][-1]) print("Get...") cl = ss.makefile() buf = b"" buf += "GET / HTTP/1.0\r\n" buf += "\r\n" cl.write(buf) while 1: l = cl.readline() print(l) if l == b"\r\n": break ss.close()Where do I lookup the -30592 error? Any other insight appreciated! Thank you in advance.
 @this-wiederkehr I think it the same way as you do. There is no parameter named as server_hostname in the docs.
 @peterson79 said in SSL socket fails with OSError: -30592: ss = ssl.wrap_socket(ss) BTW: have you tried adding parameters to this call? Like, do you need to supplie a client cert, or does the server require you to use SNI? See the docs here:
 https://docs.pycom.io/chapter/firmwareapi/micropython/ussl.htmlRegarding SNI there is an undocumented keyword parameter server_hostnamesee my post here: https://forum.pycom.io/topic/2065/sni-on-tls-connections/2Finally: If you intend to do an http request consider using urequests from here: https://github.com/micropython/micropython-lib/tree/master/urequests
 You have to translate the error code to hex and search for it on the mbed tls implementation:
 https://tls.mbed.org/api/ssl_8h.html#acc37a34787c5c5484a993ff64c3a163430592 is 0x7780
 Which meansA fatal alert message was received from our peer.honestly I have no clue what this message implies ...
 I haven't found a solution, a standard connection seems to work through a dedicated server but not though ZEIT. Probably due to some proxy or load balancer would be my guess... I haven't found a way to lookup the error either...
 @peterson79, have you solved the error? I'm facing similar problem while using SSL.
