    New firmware release 0.9.3.b2
    22 Posts 9 Posters 9.9k Views 11 Watching
      daniel
      We are pleased to announce that firmware version 0.9.3.b2 has been released today. We have fixed the broken FTP server issue from the previous version.
      These are the changes:
      Increase LWIP max number of sockets from 4 to 6.
      Add the PWM class to the machine module.
      Add the ADC class in the machine module.
      Correct UART interrupt enabling to pass the uart id.
      Fix bug when using node addresses >= 0x80000000 for LoRaWAN ABP join.
      Add API to add and remove LoRa channels.
      New LoRaWAN join API. Implement DR socket option.
      Add _thread module.
      We've also improved the updater tool in order to show a verbose output in case of a failure during the update. As usual, you can download the new firmware from:
      https://www.pycom.io/support/supportdownloads/
      (Under the Firmware Updates section)
      Please check the quick reference to see examples of using the ADC class, the PWM class and the _thread module while we update the docs with the full reference.
      https://docs.pycom.io/lopy/lopy/quickref.html
      I also want to mention that we published our iOS mobile App Pymate in the Apple App store. Go ahead and try it now!
      Cheers,
      Daniel
      • X Offline
        Xykon administrators
        Still crashes for me during boot when trying to run in WIFI STA mode and connect to my AP.
        ets Jun  8 2016 00:22:57
        configsip: 0, SPIWP:0x00
        mode:QIO, clock div:2
        load:0x3fff9010,len:8
        load:0x3fff9018,len:312
        load:0x40078000,len:2348
        ho 0 tail 12 room 4
        load:0x4009f000,len:1364
        entry 0x4009f2f8
        rtc v112 Sep 26 2016 22:32:10
        XTAL 40M
        frc2_timer_task_hdl:3ffda4a8, prio:22, stack:2048
        tcpip_task_hdlxxx : 3ffdec74, prio:18,stack:2048
        phy_version: 123, Sep 13 2016, 20:01:58, 0
        pp_task_hdl : 3ffdfe24, prio:23, stack:8192
        mode : softAP(24:0a:xx:xx:xx:xx)
        dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
        mode : sta(24:0a:xx:xx:xx:xx)
        n:7 2, o:6 0, ap:255 255, sta:7 2, prof:6
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        connected with WIFISSID, channel 7
        Task watchdog got triggered. The following tasks did not feed the watchdog in time:
        Tasks currently running:
        CPU 0: MicroPy
        Aborting.
        Guru Meditation Error: Core   0 panic'ed (Unhandled debug exception)
        Register dump:
        PC      :  4000bff0  PS      :  00060036  A0      :  80084de8  A1      :  3ffd51f0
        A2      :  0000000a  A3      :  0000000a  A4      :  00000004  A5      :  00000000
        A6      :  00000000  A7      :  fffffff8  A8      :  00000000  A9      :  3ffd5160
        A10     :  00000000  A11     :  3ffdd7b3  A12     :  3ffd512f  A13     :  00000030
        A14     :  00000000  A15     :  00000001  SAR     :  00000019  EXCCAUSE:  00000001
        EXCVADDR:  00000000  LBEG    :  4000c349  LEND    :  4000c36b  LCOUNT  :  ffffffff
        CPU halted.
        Christian Ehlers
        • X Offline
          OK I modified my boot.py file to avoid the crash...
          import os
          uart = machine.UART(0, 115200) # disable these two lines if you don't want serial access
          os.dupterm(uart)
          if machine.reset_cause() != machine.SOFT_RESET: # needed to avoid losing connection after a soft reboot
              from network import WLAN
              wl = WLAN()
              # save the default ssid and auth
              original_ssid = wl.ssid()
              original_auth = wl.auth()
              wl.mode(WLAN.STA)
              try:
                  wl.connect('MYWIFI', (WLAN.WPA2, 'MYPWD'), timeout=10000)
              except:
                  wl.init(mode=WLAN.AP, ssid=original_ssid, auth=original_auth, channel=6, antenna=WLAN.INT_ANT)
          In my previous script I would have seen this is the last lines after boot:
          MicroPython d78a5a3 on 2016-11-05; LoPy with ESP32
          Now I get these extra messages:
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          And I have to press enter to get the >>> prompt
          I'm guessing this has to do with the new threading implementation... the try: block is opening a new thread which causes the WDT to reset and this is why the boot.py manages to complete without causing the WDT to expire.
          Christian Ehlers
            livius
            New firmware
            >>> os.uname()
            (sysname='WiPy', nodename='WiPy', release='0.9.3.b2', version='d78a5a3 on 2016-11-05', machine='WiPy with ESP32')
            Still can not connect to WiPy2 from Pymakr by COM port
            ho 0 tail 12 room 4
            entry 0x4009f2f8
            XTAL 40M
            frc2_timer_task_hdl:3ffd9898, prio:22, stack:2048
            tcpip_task_hdlxxx : 3ffde064, prio:18,stack:2048
            pp_task_hdl : 3ffdf8b0, prio:23, stack:8192
            mode : softAP(24:0a:c4:00:a8:bf)
            MicroPython d78a5a3 on 2016-11-05; WiPy with ESP32
              dalecousins
              Hi all great work you guys are doing i have 2 LOPY's which i have updated and have running with a fixed IP attached to my AP at home i'm running on a MBP on macos 10.12.2 and when i downloaded the current updater it will not open, i get the PY icon for about a second and then it disappears.
              Any help would be great thanks.
              Dale.
              • M Offline
                MainSheet
                I just updated 2 LoPy's to 0.9.3.b2. After updating I have not been able to communicate with either using telnet, ftp or PyMakr .
                I tried all 3 safe boot modes on both devices, no luck. Every once and a while I will get a >>> prompt but within seconds I get a connection error.
                Otherwise, they seem to be working, both a updateable, heart beat led is working and when in safe boot mode they both come up as APs, and I can get a connection to them when they are in AP mode.
                • X Offline
                  Xykon administrators @MainSheet
                  @MainSheet Can you post the output you get on the serial port?
                  Christian Ehlers
                  • M Offline
                    MainSheet @Xykon
                    @Xykon most of the time I get this, :
                    Connecting to a Pycom device...
                    Error while communicating with the Pycom device! (click to attempt to reconnect)
                    Occasionally there will be a normal connection in between but it only stays up for a few seconds.
                    few other details
                    Tried PyMakr in Windows10 and Ubuntu .
                    can't connect with Putty or Filezilla.
                    PyMakr is 1.0.0.b6
                    Thanks for the help
                    Steve
                    • X Offline
                      @MainSheet Can you check with putty in serial mode? Set connection type to Serial, adjust the Serial line COM port number and set a speed of 115200. Make sure PyMakr is closed and click Open
                      alt text
                      Then press the reset button on the WiPy2/LoPy and post the output you get.
                      When you post the output please surround it with ``` before and after the output.
                      Christian Ehlers
                      • M Offline
                        MainSheet @Xykon
                        @Xykon
                        ok
                        unit one does this
                        ho 0 tail 12 room 4
                        entry 0x4009f2f8
                        XTAL 40M
                        frc2_timer_task_hdl:3ffda618, prio:22, stack:2048
                        tcpip_task_hdlxxx : 3ffdede4, prio:18,stack:2048
                        pp_task_hdl : 3ffea6b4, prio:23, stack:8192
                        mode : softAP(24:0a:c4:00:bd:0f)
                        (note: unit one never gets to a >>> prompt)
                        Unit 2 gets
                        ho 0 tail 12 room 4
                        entry 0x4009f2f8
                        XTAL 40M
                        pp_task_hdl : 3ffea740, prio:23, stack:8192
                        mode : softAP(24:0a:c4:00:12:c1)
                        mode : sta(24:0a:c4:00:12:c0)
                        n:1 0, o:6 0, ap:255 255, sta:1 0, prof:6
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        connected with goofy, channel 1
                        ('192.168.0.118', '255.255.255.0', '192.168.0.1', '192.168.0.1')
                        • X Offline
                          @MainSheet For Unit1 it seems either your boot.py is missing the code for the serial REPL or it contains an error which prevents it from being executed. You should however be able to connect to it through Wifi and telnet / ftp to 192.168.4.1. You should check that your Wifi settings are correct when connecting to the module via Wifi. Can you try to ping 192.168.4.1 to check if your network connection to the module is working? You should at least be able to use putty in telnet mode to connect to 192.168.4.1. You can then run execfile('boot.py') to see if there are any errors in your boot.py.
                          For Unit2 this seems to be able to connect to your Wifi AP. Check this one also with ping 192.168.0.118 to make sure it is reachable over the network. You should then be able to telnet & ftp to 192.168.0.118. Make sure that your Filezilla settings are correct as described here. In putty make sure you choose telnet protocol and not the default ssh.
                          Christian Ehlers
                          • M Offline
                            MainSheet @Xykon
                            @Xykon , First, thanks for all your help, I have both units working now.
                            Both units had zero byte files in the /flash folder. I believe this was a result of using the PyMakr sync project button, as that was the last tool I used to upload files.
                            I still can not get the PyCom console in PyMAkr to load the REPL prompt. PyMakr is configured on COM4, the same port I used successfully for putty (serialmode).
                            I also configured PyMakr for 192.168.0.118, still could not load the REPL prompt.
                            • M Offline
                              matamune
                              I am on macOS Sierra and when I downloaded the newest version of the updater, I was not able to launch it.
                              I debbuged it by launching it on the terminal and it says the file lopy.py did not find the folder 'firmware'.
                              I took a look into the code and in the function __establishFirmwareVersion, line 426, I had to change bins = os.listdir('/firmware')by bins = os.listdir(HERE_PATH+'/firmware').
                              Now it works correctly.
                              K A 2 Replies Last reply Reply Quote 0
                              • X Offline
                                @MainSheet I only used PyMakr very briefly (it keeps turning the awfully bright LED on and it's very annoying having to turn it off manually all the time) but it was working with the LoPy and the latest firmware.
                                The only reasons I can think of why PyMakr can't connect to the serial port is that something else is blocking the COM port or there is something in your boot.py/main.py that's causing PyMakr to fail. You could try import os; import machine; os.mkfs('/flash'); machine.reset() to restore your flash memory to firmware defaults, it will re-create a boot.py with nothing but the code for serial REPL along with empty main.py and sys, cert, lib directories.
                                As for not being able to connect via the network, did you try ping 192.168.0.118 from the command line? Did you try putty in telnet mode and FileZilla with correct settings?
                                Christian Ehlers
                                • K Offline
                                  kurt @matamune
                                  @matamune said in New firmware release 0.9.3.b2:
                                  Yes! This makes the firmware updater working on the MacOs. I'm on El Capitain.
                                  To be a bit more specific, one need to apply the fix in here:
                                  /Applications/Pycom Firmware Update.app/Contents/Resources/src/lopyupdate.py
                                    dalecousins
                                    Thanks guys that worked.
                                    Dale.
                                    • M Offline
                                      MainSheet @Xykon
                                      @Xykon I think I will put PyMakr to the side for a while, between FileZilla and putty I can do whatever I need. Your input has helped me get up to speed quickly. Thanks
                                        abilio @matamune
                                        @matamune, thanks for your observation. There is a new version of the script that takes into account your findings. It should start now :) It's available in the usual place, and the file is named pycom_update_0.9.3.b2a.dmg
                                          scratchrobot
                                          FTP still not working for me after upgrading to pycom_update_0.9.3.b2.dmg
                                            livius
                                            I do not have mac but did you checked real version it it was upgraded?
                                            import os
                                            os.uname()
                                            • 1
                                            • 2
                                            • 2 / 2
