    PyTrack LoRa & LiPo
    pytracklipo batteryloraaccelerometergps
    3 Posts 2 Posters 1.5k Views 2 Watching
      pymiom
      Hi Guys,
      I have been doing some testing with the PyTrack and have two questions. I am running code very similar to this:
      https://startiot.telenor.com/learning/pytrack-quick-start-guide/
      The questions are:
      1. When I use a LiPo battery, data is sent to my LoRa provider (Loriot), but it is all zeros and null values ( am am inside so GPS will be zero, but does work outside :))
        None,None,0,0,0
      When I am connected via USB, it looks like so:
      None,None,6.017615,57.97042,-57.27425
      1. On the above code, once connected to the LoRa network, the accelerometer data never changes, it always stays at the same value until I reboot the device.
      Thanks for any help :)
      • X Offline
        Xykon administrators @pymiom
        @pymiom said in PyTrack LoRa & LiPo:
        Can you please indicate what type and capacity of LiPo battery you are using?
        Please try to call the acceleration() method before calling read()
        Christian Ehlers
          pymiom
          Hi @Xykon ,
          Thanks for reply, that works for the PySense update!
          The Battery I am using is a 3.7v 2000mAh.
          Michael
