    [SOLVED] Errors building frozen bytecode
    frozen
    2 Posts 1 Posters 927 Views 1 Watching
    • B Offline
      BetterAuto Pybytes Beta
      I am getting the following error when building frozen_mpy.c. I followed these directions to set up my environment and I was able to successfully build a firmware without my custom modules in the frozen directory. But when I pulled them in it errors out. Not sure how to proceed.
      Build commands:
      make clean
      export IDF_PATH=~/pycom-esp-idf
      export BUILD_VERBOSE=true
      make BOARD=WIPY TARGET=boot
      make BOARD=WIPY TARGET=app
      And here is my verbose build log:
      https://pastebin.com/iYkW0Ety
      build/WIPY/release/frozen_mpy.c:7828:47: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_test_threading.old__lt_module_gt__Testing___init__[87] = {
      build/WIPY/release/frozen_mpy.c:7864:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_test_threading.old__lt_module_gt__Testing___init___0 = {{&mp_type_str}, 32756, 40, (const byte*)"\x54\x65\x73\x74\x69\x6e\x67\x20\x65\x78\x63\x65\x70\x74\x69\x6f\x6e\x20\x6c\x6f\x67\x67\x69\x6e\x67\x20\x69\x6e\x73\x69\x64\x65\x20\x61\x20\x63\x6c\x61\x73\x73"};
      build/WIPY/release/frozen_mpy.c:7865:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_test_threading.old__lt_module_gt__Testing___init___1 = {{&mp_type_str}, 34209, 22, (const byte*)"\x57\x65\x20\x73\x68\x6f\x75\x6c\x64\x6e\x27\x74\x20\x67\x65\x74\x20\x68\x65\x72\x65\x2e"};
      build/WIPY/release/frozen_mpy.c:7866:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_test_threading.old__lt_module_gt__Testing___init__[3] = {
      build/WIPY/release/frozen_mpy.c:7871:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_test_threading.old__lt_module_gt__Testing___init__ = {
      build/WIPY/release/frozen_mpy.c:7887:47: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_test_threading.old__lt_module_gt__Testing[60] = {
      build/WIPY/release/frozen_mpy.c:7911:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_test_threading.old__lt_module_gt__Testing[1] = {
      build/WIPY/release/frozen_mpy.c:7914:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_test_threading.old__lt_module_gt__Testing = {
      build/WIPY/release/frozen_mpy.c:7930:47: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_test_threading.old__lt_module_gt__testing[95] = {
      build/WIPY/release/frozen_mpy.c:7971:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_test_threading.old__lt_module_gt__testing_0 = {{&mp_type_str}, 58712, 43, (const byte*)"\x54\x65\x73\x74\x69\x6e\x67\x20\x65\x78\x63\x65\x70\x74\x69\x6f\x6e\x20\x6c\x6f\x67\x67\x69\x6e\x67\x20\x69\x6e\x73\x69\x64\x65\x20\x61\x20\x66\x75\x6e\x63\x74\x69\x6f\x6e"};
      build/WIPY/release/frozen_mpy.c:7972:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_test_threading.old__lt_module_gt__testing_1 = {{&mp_type_str}, 34209, 22, (const byte*)"\x57\x65\x20\x73\x68\x6f\x75\x6c\x64\x6e\x27\x74\x20\x67\x65\x74\x20\x68\x65\x72\x65\x2e"};
      build/WIPY/release/frozen_mpy.c:7973:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_test_threading.old__lt_module_gt__testing[2] = {
      build/WIPY/release/frozen_mpy.c:7977:51: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_test_threading.old__lt_module_gt__testing = {
      build/WIPY/release/frozen_mpy.c:7993:47: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_test_threading.old__lt_module_gt_[37] = {
      build/WIPY/release/frozen_mpy.c:8009:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_test_threading.old__lt_module_gt_[2] = {
      build/WIPY/release/frozen_mpy.c:8013:44: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       const mp_raw_code_t raw_code_test_threading.old__lt_module_gt_ = {
      build/WIPY/release/frozen_mpy.c:10878:42: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_deepsleep.non-shield__lt_module_gt__deepsleep[289] = {
      build/WIPY/release/frozen_mpy.c:11019:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_deepsleep.non-shield__lt_module_gt__deepsleep_0 = {{&mp_type_str}, 35400, 16, (const byte*)"\x44\x4f\x4f\x52\x5f\x52\x45\x45\x44\x5f\x55\x50\x5f\x50\x49\x4e"};
      build/WIPY/release/frozen_mpy.c:11020:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_deepsleep.non-shield__lt_module_gt__deepsleep_1 = {{&mp_type_str}, 42727, 16, (const byte*)"\x44\x4f\x4f\x52\x5f\x52\x45\x45\x44\x5f\x44\x4e\x5f\x50\x49\x4e"};
      build/WIPY/release/frozen_mpy.c:11021:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_deepsleep.non-shield__lt_module_gt__deepsleep_2 = {{&mp_type_str}, 34342, 12, (const byte*)"\x41\x55\x58\x5f\x57\x41\x4b\x45\x5f\x50\x49\x4e"};
      build/WIPY/release/frozen_mpy.c:11022:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_deepsleep.non-shield__lt_module_gt__deepsleep_3 = {{&mp_type_str}, 30107, 12, (const byte*)"\x77\x61\x6b\x65\x5f\x70\x69\x6e\x73\x3a\x20\x27"};
      build/WIPY/release/frozen_mpy.c:11023:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_deepsleep.non-shield__lt_module_gt__deepsleep_4 = {{&mp_type_str}, 52300, 25, (const byte*)"\x53\x69\x6d\x75\x6c\x61\x74\x69\x6e\x67\x20\x64\x65\x65\x70\x20\x73\x6c\x65\x65\x70\x20\x6f\x66\x20"};
      build/WIPY/release/frozen_mpy.c:11024:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_deepsleep.non-shield__lt_module_gt__deepsleep_5 = {{&mp_type_str}, 48481, 43, (const byte*)"\x53\x69\x6d\x75\x6c\x61\x74\x69\x6e\x67\x20\x64\x65\x65\x70\x20\x73\x6c\x65\x65\x70\x20\x6f\x66\x20\x69\x6e\x64\x65\x66\x69\x6e\x69\x74\x65\x20\x6c\x65\x6e\x67\x74\x68\x2e"};
      build/WIPY/release/frozen_mpy.c:11025:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_deepsleep.non-shield__lt_module_gt__deepsleep[7] = {
      build/WIPY/release/frozen_mpy.c:11034:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_deepsleep.non-shield__lt_module_gt__deepsleep = {
      build/WIPY/release/frozen_mpy.c:11050:42: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_deepsleep.non-shield__lt_module_gt_[25] = {
      build/WIPY/release/frozen_mpy.c:11063:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_deepsleep.non-shield__lt_module_gt_[1] = {
      build/WIPY/release/frozen_mpy.c:11066:39: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       const mp_raw_code_t raw_code_deepsleep.non-shield__lt_module_gt_ = {
      build/WIPY/release/frozen_mpy.c:20214:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_tests_test_threading.old__lt_module_gt__Testing___init__[87] = {
      build/WIPY/release/frozen_mpy.c:20250:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_tests_test_threading.old__lt_module_gt__Testing___init___0 = {{&mp_type_str}, 32756, 40, (const byte*)"\x54\x65\x73\x74\x69\x6e\x67\x20\x65\x78\x63\x65\x70\x74\x69\x6f\x6e\x20\x6c\x6f\x67\x67\x69\x6e\x67\x20\x69\x6e\x73\x69\x64\x65\x20\x61\x20\x63\x6c\x61\x73\x73"};
      build/WIPY/release/frozen_mpy.c:20251:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_tests_test_threading.old__lt_module_gt__Testing___init___1 = {{&mp_type_str}, 34209, 22, (const byte*)"\x57\x65\x20\x73\x68\x6f\x75\x6c\x64\x6e\x27\x74\x20\x67\x65\x74\x20\x68\x65\x72\x65\x2e"};
      build/WIPY/release/frozen_mpy.c:20252:61: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_tests_test_threading.old__lt_module_gt__Testing___init__[3] = {
      build/WIPY/release/frozen_mpy.c:20257:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_tests_test_threading.old__lt_module_gt__Testing___init__ = {
      build/WIPY/release/frozen_mpy.c:20273:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_tests_test_threading.old__lt_module_gt__Testing[60] = {
      build/WIPY/release/frozen_mpy.c:20297:61: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_tests_test_threading.old__lt_module_gt__Testing[1] = {
      build/WIPY/release/frozen_mpy.c:20300:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_tests_test_threading.old__lt_module_gt__Testing = {
      build/WIPY/release/frozen_mpy.c:20316:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_tests_test_threading.old__lt_module_gt__testing[95] = {
      build/WIPY/release/frozen_mpy.c:20357:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_tests_test_threading.old__lt_module_gt__testing_0 = {{&mp_type_str}, 58712, 43, (const byte*)"\x54\x65\x73\x74\x69\x6e\x67\x20\x65\x78\x63\x65\x70\x74\x69\x6f\x6e\x20\x6c\x6f\x67\x67\x69\x6e\x67\x20\x69\x6e\x73\x69\x64\x65\x20\x61\x20\x66\x75\x6e\x63\x74\x69\x6f\x6e"};
      build/WIPY/release/frozen_mpy.c:20358:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_tests_test_threading.old__lt_module_gt__testing_1 = {{&mp_type_str}, 34209, 22, (const byte*)"\x57\x65\x20\x73\x68\x6f\x75\x6c\x64\x6e\x27\x74\x20\x67\x65\x74\x20\x68\x65\x72\x65\x2e"};
      build/WIPY/release/frozen_mpy.c:20359:61: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_tests_test_threading.old__lt_module_gt__testing[2] = {
      build/WIPY/release/frozen_mpy.c:20363:57: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_raw_code_t raw_code_tests_test_threading.old__lt_module_gt__testing = {
      build/WIPY/release/frozen_mpy.c:20379:53: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_tests_test_threading.old__lt_module_gt_[37] = {
      build/WIPY/release/frozen_mpy.c:20395:61: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_tests_test_threading.old__lt_module_gt_[2] = {
      build/WIPY/release/frozen_mpy.c:20399:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       const mp_raw_code_t raw_code_tests_test_threading.old__lt_module_gt_ = {
      build/WIPY/release/frozen_mpy.c:24650:37: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const byte bytecode_data_main.final__lt_module_gt_[663] = {
      build/WIPY/release/frozen_mpy.c:24912:41: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_obj_str_t const_obj_main.final__lt_module_gt__0 = {{&mp_type_str}, 21005, 14, (const byte*)"\x62\x61\x74\x74\x65\x72\x79\x5f\x63\x68\x61\x72\x67\x65"};
      build/WIPY/release/frozen_mpy.c:24913:45: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       STATIC const mp_uint_t const_table_data_main.final__lt_module_gt_[1] = {
      build/WIPY/release/frozen_mpy.c:24916:34: error: expected '=', ',', ';', 'asm' or '__attribute__' before '.' token
       const mp_raw_code_t raw_code_main.final__lt_module_gt_ = {
      build/WIPY/release/frozen_mpy.c:29774:6: error: 'raw_code_test_threading' undeclared here (not in a function)
           &raw_code_test_threading.old__lt_module_gt_,
      build/WIPY/release/frozen_mpy.c:29782:6: error: 'raw_code_deepsleep' undeclared here (not in a function)
           &raw_code_deepsleep.non-shield__lt_module_gt_,
      build/WIPY/release/frozen_mpy.c:29782:29: error: 'shield__lt_module_gt_' undeclared here (not in a function)
      build/WIPY/release/frozen_mpy.c:29812:6: error: 'raw_code_tests_test_threading' undeclared here (not in a function)
           &raw_code_tests_test_threading.old__lt_module_gt_,
      build/WIPY/release/frozen_mpy.c:29823:6: error: 'raw_code_main' undeclared here (not in a function)
           &raw_code_main.final__lt_module_gt_,
      make: *** [build/WIPY/release/build/WIPY/release/frozen_mpy.o] Error 1[0_1507594978110_build.log](Uploading 100%)
      • B Offline
        Found the problem quickly. I read the error message very carefully and found the file name embedded in that long STATIC variable name. Those were some old/unnecessary test code and when I removed them, it compiled.
