problem with wifi init
I try to connect the wipy2 to my network but I have always an error on wlan.init()
I used the code witch is proposed on the pycom documentationimport machine
from network import WLAN
wlan = WLAN() # get current object, without changing the modeif machine.reset_cause() != machine.SOFT_RESET:
wlan.init(mode=WLAN.STA)
# configuration below MUST match your home router settings!!
wlan.ifconfig(config=('192.168.178.107', '255.255.255.0', '192.168.178.1', '8.8.8.8'))if not wlan.isconnected():
# change the line below to match your network ssid, security and password
wlan.connect('mywifi', auth=(WLAN.WPA2, 'mywifikey'), timeout=5000)
while not wlan.isconnected():
machine.idle() # save power while waitingthe error is
Traceback (most recent call last):File "boot.py", line 6, in <module>
TypeError: extra positional arguments given
Have you an idea?
Thanks.
Anthony -
Can you please check your firmware version?
import os os.uname()
