    LoPy Beta Release (version='v1.8.1-53-ga8a6e4b on 2016-06-29')
    1 Posts 1 Posters 1.2k Views 2 Watching
      daniel
      First of all, make sure you have followed the getting started instructions, which can be found in: https://cloud.pycom.io/index.php/s/fb19uo4IaEdMldR
      The actual IP address for FTP and telnet is: 192.168.4.1
      A new release is available which bring bug fixes and a newly added LoRa class as part of the network module.
      IMPORTANT NOTE: All jumpers except for the Tx and Rx of the UART need to be removed from the expansion board in order for LoRa to work (this won't be needed on the production version of the LoPy). See the attached picture for reference.
      These are the release notes for version='v1.8.1-53-ga8a6e4b on 2016-06-29'
      New features:
      • LoRa class contructor permits to invert the Tx and Rx IQ signals.
      • Minimal time module
      Example code:
      from network import LoRa
      lora = LoRa() # initialize with recommended settings
      lora.send('LoRa packet test', False)  # Send data in a synchronous way
      lora.recv() # get any data pending in the receive queue
      In order to send LoRa packets between your 2 LoPys:
      • In LoPy # 1:
      # initialize LoRa as a node (with Rx IQ inversion)
      lora = LoRa(tx_iq=False, rx_iq=True)
      for i in range(10):
          lora.send('LoRa packet test #{}'.format(i), False)  # Send data in a synchronous way
      • In LoPy # 2:
      # initialize LoRa as a Gateway (with Tx IQ inversion)
      lora = LoRa(tx_iq=True, rx_iq=False)
      for i in range(10):
          print(lora.recv())  # just receive
          time.sleep(1.5) # wait for 1500 milliseconds
      The releases are available here:
      https://cloud.pycom.io/index.php/s/khCswKQ6qUmj1n7 (868MHz band)
      https://cloud.pycom.io/index.php/s/sU6fbDIqLF6r1U1 (915MHz band)
      Tip: use os.uname() to get the software version information.
