Guru Meditation Error: Core 0 panic'ed (Unhandled debug exception) because of watchdog not feed in time
  • Hi,
    With the new firmware update, I get an new error that I did not have previously:
    >>> execfile("clock.py")
    Task watchdog got triggered. The following tasks did not feed the watchdog in time:
    Tasks currently running:
    CPU 0: MicroPy
    Aborting.
    Register dump:
    PC      :  400f2405  PS      :  00060036  A0      :  800ea6bd  A1      :  3ffd51f0
    A2      :  0000000a  A3      :  0000000a  A4      :  00000004  A5      :  00000000
    A6      :  00000000  A7      :  fffffff8  A8      :  00000000  A9      :  3ffd5160
    A10     :  00000000  A11     :  3ffdd7b3  A12     :  3ffd512f  A13     :  00000030
    A14     :  00000000  A15     :  00000002  SAR     :  00000011  EXCCAUSE:  00000001
    EXCVADDR:  00000000  LBEG    :  4000c46c  LEND    :  4000c477  LCOUNT  :  00000000
    CPU halted.
    Here is my code:
    from machine import Pin
    SEGMENT_ON=0
    SEGMENT_OFF=1
    DIGIT_ON=1
    DIGIT_OFF=0
    HOURS=3
    MINUTES=4
    SECONDS=5
    #   _b_
    # a|   |
    #  |_h_|c
    # g|___|e .d
    #    f
    a=Pin('P10', mode=Pin.OUT)          #GP17
    b=Pin('P11', mode=Pin.OUT)          #GP22
    c=Pin('P21', mode=Pin.OUT) #7       #GP8
    d=Pin('P3', mode=Pin.OUT)           #GP24
    e=Pin('P4', mode=Pin.OUT)           #GP11
    f=Pin('P2', mode=Pin.OUT)           #GP23
    g=Pin('P19', mode=Pin.OUT)#1         #GP7
    h=Pin('P23', mode=Pin.OUT)#5        #GP10
    digit1=Pin('P12', mode=Pin.OUT)     #GP20
    digit2=Pin('P9', mode=Pin.OUT)      #GP16
    digit3=Pin('P8', mode=Pin.OUT)      #GP15
    digit4=Pin('P22', mode=Pin.OUT) #6  #GP9
    digits= [digit1,digit2,digit3,digit4]
    digitSegments={
        1 : (c, e),
        2 : (b, c, h, g, f),
        3 : (b, c, h, e, f),
        4 : (a, h, c, e),
        5 : (b, a, h, e, f),
        6 : (b, a, h, g, f, e),
        7 : (b, c, e),
        8 : (a, b, c, e, f, g, h),
        9 : (a, b, c, e, f, h),
        0 : (a, b, c, e, f, g)
    def displayDigitSegment(digitSegmentsToDisplay):
        global digitSegments
        global SEGMENT_ON
        #Switch on the segments of the digit
        for digit in digitSegments.get(digitSegmentsToDisplay):
            digit.value(SEGMENT_ON)
        time.sleep_us(1000)
        for disableOldSegment in digitSegments.get(8):
            disableOldSegment.value(SEGMENT_OFF)
        return
    digit1.value(DIGIT_OFF)
    digit2.value(DIGIT_OFF)
    digit3.value(DIGIT_OFF)
    digit4.value(DIGIT_OFF)
        clock=time.localtime(time.time())
        sec=clock[SECONDS]
        minu=clock[MINUTES]
        for digitNum in range (0, 4):
            currDigit=digits[digitNum]
            currDigit.value(DIGIT_ON)
            if digitNum == 0:
                displayDigitSegment(minu//10)
            elif digitNum == 1:
                displayDigitSegment(minu%10)
            elif digitNum == 2:
                displayDigitSegment(sec//10)
                displayDigitSegment(sec%10)
            currDigit.value(DIGIT_OFF)
    It is a 4 digit 7 segment display that I use to display the current minutes and seconds.
    Later, I want to display the current temperature of my room.
    Has anyone encountered this error before? And if yes, have you managed to solve it and how?
    Thank you :)
  • Try a time.sleep_ms(1) in your loop
  • With the thread example:
    import _thread
    def th_func(delay, id):
            time.sleep(delay)
            print('Running thread %d' % id)
    for i in range(2):
        _thread.start_new_thread(th_func, (i + 1, i))
    it runs fine, but I cant quit with ctrl-c, and with ctrl-d it
    PYB: soft reboot
    �MicroPython d78a5a3 on 2016-11-05; WiPy with ESP32
    >>> Guru Meditation Error of type LoadProhibited occurred on core   0. Exception was unhandled.
    Register dump:
    PC      :  40085076  PS      :  00060433  A0      :  8008350d  A1      :  3ffdd3f0
    A2      :  3ffb00dc  A3      :  3ffdd4f4  A4      :  8008382f  A5      :  3ffdc970
    A6      :  00000003  A7      :  00060e23  A8      :  00000000  A9      :  3ffb1248
    A10     :  00000000  A11     :  00006711  A12     :  00060423  A13     :  b33f0000
    A14     :  b33fffff  A15     :  00060e23  SAR     :  0000001a  EXCCAUSE:  0000001c
    EXCVADDR:  00000000  LBEG    :  00000000  LEND    :  00000000  LCOUNT  :  00000000
    CPU halted.
    on Wipy2
