    "resource not available" when assigning P9 / G16 as ADC
    adc
    13 Posts 4 Posters 2.6k Views 4 Watching
    • sorenS Offline
      soren
      After much headache I discovered this post (https://forum.pycom.io/topic/313/lopy-pin-out/3)
      where one user says that it's possible to find the correlation between chip pins and expansion board pins with a REPL command.
      And so I found out that P9 on the chip is G16 on the expansion board and this pin should have ADC capability.
      So I wrote in my code:
      adc = machine.ADC()
      sensorPin = adc.channel(pin="P9")
      But it keeps throwing a "OSError: resource not available" on that second line. I did import machine.
      What is this supposed to mean? That P9 is not G16 after all, or despite this diagram (https://docs.pycom.io/chapter/datasheets/downloads/lopy-pinout.pdf) saying that P9 has ADC, it does not? Or that some other feature on this port prevents me from using it?
      EDIT: after making sure I wasn't using ADC2 ( the ones on the left side), I got rid of this error for some time. Now it's come back, and it doesn't matter which pin I use: ADC is just not available as a resource, and I'm getting no clue what so ever as to why this is..
        jmarcelino @soren
        @soren
        The ADC2 pins are not available from Python, at least for the time being. You can only use ones starting with ADC1_...
        sorenS H 3 Replies Last reply Reply Quote 0
        • sorenS Offline
          soren @jmarcelino
          @jmarcelino thank you very much for chiming in. i'm baffled why this isn't stated in capital letters on the official pinout diagrams
          • sorenS Offline
            soren @jmarcelino
            @jmarcelino so now I'm also getting this error from ADC1 pins... P14, to be precise
              robert-hh @soren
              @soren Are sou sure? I can do it here.
              adc = machine.ADC()
              sensorPin = adc.channel(pin="P14")
              sorenS 1 Reply Last reply Reply Quote 1
              • sorenS Offline
                soren @robert-hh
                @robert-hh
                Hi robert, as far as I can tell - I'm doing the same thing as you.. here is my code, it's on line 9 ("sensorPin = adc...) it reports this error:
                from machine import Pin
                from machine import ADC
                from machine import PWM
                adc = machine.ADC()
                sensorPin = adc.channel(pin='P23', attn=ADC.ATTN_11DB) # G4 on expansion board
                ledArray = [0x7f0000, 0x007f00, 0x0000ff] # red, green, blue
                step_p = Pin('P8', mode=Pin.OUT)
                stepDir_p = Pin('P21', mode=Pin.OUT)
                class ColorSensor:
                    dosingPump_p = Pin('P21', mode=Pin.OUT)
                    dosingPump_p.value(0)
                    # SERVO:
                    pwm = PWM(0, frequency=50)
                    servo_p = pwm.channel(0, pin='P22', duty_cycle=0.127)
                    servo_p.duty_cycle(0.107)
                    # 0.107 # upright position
                    # 0.03 # pouring position
                    balanceSet = False
                    colourArray = [0, 0, 0]
                    whiteArray = [0, 0, 0]
                    blackArray = [0, 0, 0]
                    avgRead = 0
                    def checkBalance(self):
                        print("checking balance")
                        if not self.balanceSet:
                            self.setBalance()
                    def setBalance(self):
                        print("setting balance")
                        time.sleep(5)
                        for num in range(0, 3): # set white bal
                            print(num)
                            pycom.rgbled(ledArray[num]) # set to color
                            time.sleep(0.1)
                            self.getReadings(5)
                            self.whiteArray[num] = self.avgRead
                            print('avgRead from bal ', self.avgRead)
                            pycom.rgbled(0x000000) # turn off led
                            time.sleep(0.1)
                        time.sleep(5)
                        for num in range(0, 3): # set black bal
                            time.sleep(0.1)
                            self.getReadings(5)
                            self.blackArray[num] = self.avgRead
                            time.sleep(0.1)
                        self.balanceSet = True
                        time.sleep(5)
                    def checkColour(self):
                        print("rinsing...")
                        for num in range(0, 3): # rinse glass 3 times
                            dosingPump_p.value(1) # take in water from aquarium
                            time.sleep_ms(500) # how much water to take in?
                            dosingPump_p.value(0) # turn off dosing pump
                            servo_p.duty_cycle(0.03) # pour out water
                            time.sleep(4)
                            servo_p.duty_cycle(0.107) # turn back glass
                            time.sleep(4)
                        print('rinsing finished! Taking in water...')
                        print('taking plunger down...')
                        for num in range(0, 201): # take plunger down
                            step_p.value(1)
                            time.sleep_ms(500)
                            step_p.value(0)
                            time.sleep_ms(500)
                            # check if plunger is all the way down and break ?
                        print('plunger is down! Waiting for analysis...')
                        time.sleep(1) # set to 3 minutes
                        print('analysis ready! Reading colours...')
                            time.sleep(0.1)
                            self.getReadings(5)
                            self.colourArray[num] = self.avgRead
                            print('whitearray ', self.whiteArray[num], ' blackArray ', self.blackArray[num])
                            greyDiff = self.whiteArray[num] - self.blackArray[num]
                            print('greydiff: ', greyDiff)
                            self.colourArray[num] = (self.colourArray[num] - self.blackArray[num])/(greyDiff)*255
                            time.sleep(0.1)
                    def printColour(self):
                        print('printing colour')
                        return self.colourArray[0], self.colourArray[1], self.colourArray[2]
                    def getReadings(self, times):
                        reading = 0
                        tally = 0
                        for num in range(0, times+1):
                            reading = sensorPin()
                            print('reading ', reading)
                            tally = reading + tally
                            time.sleep(0.01)
                        self.avgRead = (tally)/times
                        print('avgRead ', self.avgRead)
                        #print('avgRead ', avgRead)
                  robert-hh @soren
                  @soren P23 belongs to ADC2 ..... You should write P14, or G4, like you state in the comment
                  sorenS 1 Reply Last reply Reply Quote 0
                  • sorenS Offline
                    soren @robert-hh
                    @robert-hh yes, sorry i know - I have been trying with the following pins with that code i send you now: "13, 14, 15 and 23". 13, 14 and 15 is adc1.
                    I think maybe I understand the problem a tiny bit better now:
                    it happens only when I'm doing a soft reset. When I do a hard reset, it works again. Is this because a soft reset doesn't free up the pins maybe?
                    • H Offline
                      HenroRitchie @jmarcelino
                      @jmarcelino Is this still the case. I am trying to access ADC2 on a Lopy4 and get the same error OSError: resource not available. ADC1 seems to be working fine.
                        jmarcelino @HenroRitchie
                        @HenroRitchie
                        I've not followed the Pycom developments too closely but at low level ADC2 is only available when WiFi is off "ADC2 is used by the Wi-Fi driver. Therefore the application can only use ADC2 when the Wi-Fi driver has not started."
                        My guess is this complicates things in a dynamic Python environment where you can turn WiFi on and off at will so probably not a priority.
                        To be honest ADC1 is quite noisy so I avoid the ESP32 ADCs altogether and now use a more "industrial grade" external solution.
                        H robert-hhR 2 Replies Last reply Reply Quote 1
                        • H Offline
                          @jmarcelino Thank you, noted. Will design accordingly.
                            robert-hh @jmarcelino
                            @jmarcelino Hello Jose. Are you back again?
                              jmarcelino @robert-hh
                              @robert-hh
                              Hey Robert! Good to see you're still around. Not back at Pycom but some collaboration brewing up, watch this space ;-)
