    Issue with vernemq mqtt broker
    3 Posts 2 Posters 1.5k Views 3 Watching
      alfheim
      Hi
      I try to use vernemq with wipy.
      vernemq 0.14.1
      umqtt.simple (https://github.com/micropython/micropython-lib)
      wipy 2 board
      On the wipy board the following code
      from umqtt.simple import MQTTClient
      def main(server="192.168.1.150"):
          c = MQTTClient(b"ran", server)
          c.connect()
          c.publish(b"test/ran", b"hello")
          c.disconnect()
      if __name__ == "__main__":
          main()
      On the other side simple consumer in paho
      import paho.mqtt.client as mqtt  # The callback for when the client receives a CONNACK response from the server.
      def on_connect(client, userdata, rc):
          print("Connected with result code " + str(rc))
          # Subscribing in on_connect() means that if we lose the connection and
          # reconnect then subscriptions will be renewed.
          # client.subscribe("$SYS/#")
          client.subscribe('test/ran')
      # The callback for when a PUBLISH message is received from the server.
      def on_message(client, userdata, msg):
          print(msg.topic + " " + str(msg.payload))
      client = mqtt.Client()
      client.on_connect = on_connect
      client.on_message = on_message
      # client.username_pw_set('test01', password='test')
      client.connect("192.168.1.150", 1883, 60)
      # Blocking call that processes network traffic, dispatches callbacks and
      # handles reconnecting.
      # Other loop*() functions are available that give a threaded interface and a
      # manual interface.
      client.loop_forever()
      When I run the publisher, this is the error on wipy:
      File "", line 12, in
      File "", line 6, in main
      File "/flash/lib/umqtt/simple.py", line 84, in connect
      IndexError: bytes index out of range
      In the vernemq error log:
      2016-11-06 20:46:13.121 [error] <0.583.0> CRASH REPORT Process <0.583.0> with 0 neighbours crashed with reason: no match of right hand value <<0,4,77,81,84,84,4,2,0,0>> in vmq_parser:parse/4 line 71
      2016-11-06 20:46:13.121 [error] <0.583.0> Ranch listener {{0,0,0,0},1883} terminated with reason: {badmatch,<<0,4,77,81,84,84,4,2,0,0>>}
      Please let me know if you need more details
        livius
        Is this "finalized" repo?
        I go to this repo and see many not implemented code
        "asyncio"
        "calendar"
        maybe you should ask repo admins about code?
          alfheim
          I did it, check this: https://github.com/micropython/micropython-lib/issues/115
