    Atom + PyMakr Plugin: Console not working
    pymakr
    2 Posts 2 Posters 1.1k Views 2 Watching
    • H Offline
      heut
      Hi all
      I've just received my first WiPy. The firmware-update went smoothly and after that I've tried to use Atom in order to test the first commands. I've been able to get the right connection settings (I believe). At least the WiPy is shown as connected. However, the behavior is not as described in the docs as >>> is not shown. It only appears after using some function from the menu (e.g., listing all serial ports again) but when using the keyboard nothing happens.
      I'm using MacOS Sierra with Atom 1.22.0 and PyMakr Plugin 1.1.5 and 1.2 (both did not work).
      Any ideas how to solve this issue?
      heut
        crumble @heut
        @heut have a look in the thread of the latest firmware update.
        Either you wait until monday for the next fix or you can try to outcomment your UART settings in boot.py/main.py
