    Test ping/pong
    4 Posts 2 Posters 1.9k Views 3 Watching
      cswiger
      Had some fun with a ping/pong test - use one LoPy on an expansion board via usb, serial in and start up this server code: (sorry, not enough points to upload a file :)
      Then the other LoPy connected to notebook with wifi, on a breadboard w/ a single Lion cell - telnet in and enter this client code
      Then you can carry the battery LoPy or the notebook around and see what kind of distances you can get in your neighborhood. Idea from radiohead rf95 client/server example.
      The full instantiation line is (US frequency):
      lora = LoRa(mode=LoRa.LORA,frequency=913100000,tx_power=14,bandwidth=LoRa.BW_125KHZ,sf=10,preamble=8, coding_rate=LoRa.CODING_4_5,power_mode=LoRa.ALWAYS_ON, tx_iq=False, rx_iq=False, adr=False, public=True, tx_retries=1)
      K 1 Reply Last reply Reply Quote 3
      • K Offline
        KDHeard @cswiger
        @cswiger said in Test ping/pong:
        LoPy
        Thanks for sharing! Did you try a distance test at all?
        Kind regards
        Kevin Heard - Founder
        DLI Systems
        www.dli.systems| Do - Learn - Improve
          cswiger
            cswiger
            No long distance tests yet. Played with some parameters and found these max working distance settings work around the house:
            tx_power=20 (US 915 band)
            sf=12
            coding_rate=LoRa.CODING_4_8
            Changing BWto LoRa.BW_125KHZ results in faster data rate and in theory lower receiver sensitivity.
            Just found another great write up of LoRa modulation at https://www.ncbi.nlm.nih.gov/pmc/articles/PMC5038744/
