    Pysense looses connection to wipy - wipy reset
    pysensewipy2.0errorhardwarereset
    2 Posts 2 Posters 856 Views 2 Watching
      Andreas B.
      Hi folks,
      i have a Pysense board updated to 0.0.7 firmware. The corresponding wipy runs on 1.10.0.b1. After some seconds (sometimes 3, sometimes 5 or even 7 heartbeats of the wipy (blue led)) the wipy stops working. Also the (for short time enabled) connection over the serial port fails and i can only reset the wipy. Then it starts over again. some heartbeats and then failure. The serial port shows me that after the reset everything seems to be ok:
      rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      ets Jun 8 2016 00:22:57
      rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff9028,len:8
      load:0x3fff9030,len:1076
      load:0x4009fa00,len:0
      ho 12 tail 0 room 4
      load:0x4009fa00,len:15344
      entry 0x400a070c
      MicroPython v1.8.6-839-g536c958c on 2017-11-15; WiPy with ESP32
      Then I am able to use the REPL (i.e. 2+2 >>>4 ...) for some seconds and after that the wipy stops and i have no connection any more. Reset starts the process over again, but it only works for some seconds.
      For me it seems to be a hardware problem (firmware 0.0.4 same problem - different wipy, same problem - different computer, same problem). The used wipy runs perfectly with an usual expansion board.
      I would appreciate if anyone can give me a hint what causes the probelm and how to fix it?!
      Thanks in advance and greetings
      Andreas
      • X Offline
        Xykon administrators
        Can you please first try another firmware update (we have released 1.10.2.b1).
        If that doesn't help please try to format the internal flash: import os; os.mkfs('/flash')
        If that still doesn't help please email support@pycom.io
        Christian Ehlers
