    How can I set up an IP address in my WiPyW
    wipy2.0
    4 Posts 3 Posters 1.4k Views 3 Watching
      ColombianAus
      Hello Everyone,
      I set up a fixed IP address for my WiPy a while ago, and I can't remember it. How can I configure a new IP address again? I can connect using picocom command.
      Cheers
      ColombianAus
      L robert-hhR 2 Replies Last reply Reply Quote 0
        livius @ColombianAus
        @colombianaus
        instead of using picocom
        i recommend you run device in safe mode
        https://docs.pycom.io/chapter/toolsandfeatures/bootmodes.html
        it then start in AP mode
        then connect to it by ftp and replace script
          robert-hh @ColombianAus
          @colombianaus Since that must be set in main.py, you could simply dump main.py with the following commands at the REPL in picocom:
          f = open("main.py", "r")
          for _ in f.readlines():
              print(_)
          f.close()
          For boot.py, just change the name in the open statement.
            ColombianAus
            Hello @robert-hh and @livius , thanks for your suggestions. I have decided to do a full factory reset and start from scratch. However I appreciate your advise
