bluetooth.service and characteristic correlation
This is my code to set BLE settings..i do not see how these values relate to what my mobile app detects...see image
https://www.dropbox.com/s/ojsv2y2abxxspn9/tempFileForShare_20171130-235653.jpg?dl=0
bluetooth.set_advertisement(name=devicename, service_uuid=b'1234567890123456') bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb) bluetooth.advertise(True) srv1 = bluetooth.service(uuid=b'1234567890123456', isprimary=True) chr1 = srv1.characteristic(uuid=b'ab34567890123456', value=5) char1_read_counter = 0 char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char1_cb_handler) srv2 = bluetooth.service(uuid=1234, isprimary=True) chr2 = srv2.characteristic(uuid=4567, value=0x1234) char2_read_counter = 0xF0 char2_cb = chr2.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=char2_cb_handler) -
@misterlisty
When you do this:b'1234567890123456')
You're creating a list of bytes based on the ASCII value of each digit (1 = 0x31, 2=0x32 3=0x33 etc)
Your phone however shows you the hexadecimal representation of each byte. It also has a different byte ordering but you can see the b'123...' in "...33-3231" - it's just in reverse order
See my previous post on how to produce services that look as you expect:
https://forum.pycom.io/post/3279
