    Check datetime of files?
    file system
    2 Posts 2 Posters 818 Views 2 Watching
    • M Offline
      misterlisty
      I want to be able to reboot the lopy based on seeing a file version in the file directory? How do i do this?
        robert-hh
        You can get a list of files with uos.listdir(<dir>). If you tell the version by the modification data, uos.stat()[7] tells you the file modification time, given that the clock was set appropriately, and machine.reset() can be called to reset the device.
        If you do not have RTC supplied by a battery, you can set the time via ntp by:
        from machine import RTC
        rtc=RTC()
        rtc.ntp_sync("pool.ntp.org")
        Then, the file modification times are valid.
        If you use another mechanism as version indicator, like the name of a file or the content of a file, you have to define and implement it yourself.
