Convert string to integer
Using BLE to set a integer variable in my code but i can only write a hex or string value. Hoe do i convert a string or Hex value to an integer?
Unhandled exception in callback handler Traceback (most recent call last): File "main.py", line 445, in _mqtt_handler File "boot.py", line 31, in logger TypeError: unsupported types for __ge__: 'bytes', 'int'
@robert-hh, it worked, thank you.
@jclo13
I assume that the first time you called nvs_get the key 'i' did not exist, and the call returned None, which caused the error at the second line. So you will need something like:import pycom i = pycom.nvs_get('i') if i is not None: pycom.nvs_set('i', i+1) else: pycom.nvs_set('i', 0)
You could as well write it with a ternary expression:
import pycom i = pycom.nvs_get('i') pycom.nvs_set('i', 0 if i is None else i+1)
hello @robert-hh
I have this error:
Traceback (most recent call last): File "<stdin>", line 1, in <module> TypeError: unsupported types for __add__: 'NoneType', 'int'
I want to use a counter whit the deepsleep, and I am using
i = pycom.nvs_get('i') pycom.nvs_set('i', i+1)
Is there a way to make to counter?
Thank You in advance.
Jose
@misterlisty If it is a string, you can use int:
val = int("1234") -> 1234
val = int("ab13", 16) -> 43975If it is a hex string, you can use binascii.hexlify(), like
binascii.hexlify("\x12") -> '12'
If you want to convert a bytearray with bytes to an integer, you can use int.from_bytes()
val = int.from_bytes("\x12\x34", "little") --> 4660
The opposite exists too.
P.S.: These are standard Python functions. The only problem here might be, that MicoPython may not cover all variants.
