FyPy LoRa Networks
My FyPy arrived today. Does it support both 868 and 915 MHz frequencies or are their specific hardware versions for each?
@smbunn
The hardware supports both however, at least for now, there are two separate firmware images. Once you pick one region in the updater it'll use it from then on unless you request it to be deleted from Pycom's database.If you're switching between regions frequently it's recommended you compile your own firmware image from source https://github.com/pycom/pycom-micropython-sigfox . Then you can select which firmware to build with a simple option LORA_BAND=USE_BAND_868 or LORA_BAND=USE_BAND_915
1 out of 2
