<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cant tell if its a pysence or pytrack... upgrade failed&#x27;]]></title><description><![CDATA[<p dir="auto">Just got new fipy and pytrack today.<br />
It shows up on the COM ports, is selectable by 'pycom firmware update'<br />
updater responds with "cant tell if its a pysence or pytrack. upgrade failed'</p>
<p dir="auto">Cant find anything on this issue, please advise.</p>
]]></description><link>https://forum.pycom.io/topic/2379/cant-tell-if-its-a-pysence-or-pytrack-upgrade-failed</link><generator>RSS for Node</generator><lastBuildDate>Thu, 19 Nov 2026 06:19:24 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2379.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jan 2018 19:49:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cant tell if its a pysence or pytrack... upgrade failed&#x27; on Fri, 05 Jan 2018 00:41:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmarcelino" aria-label="Profile: jmarcelino">@<bdi>jmarcelino</bdi></a> said in <a href="/post/14118">cant tell if its a pysence or pytrack... upgrade failed'</a>:</p>
<blockquote>
<p dir="auto">dfu-util-static.exe -D pytrack_0.0.8.dfu</p>
</blockquote>
<p dir="auto">Thank you, the USB upgrade I was using was from an old post. Your zip process worked, and the upgrade was successful.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.pycom.io/post/14123</link><guid isPermaLink="true">https://forum.pycom.io/post/14123</guid><dc:creator><![CDATA[Laputa]]></dc:creator><pubDate>Fri, 05 Jan 2018 00:41:45 GMT</pubDate></item><item><title><![CDATA[Reply to cant tell if its a pysence or pytrack... upgrade failed&#x27; on Thu, 04 Jan 2018 23:23:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/laputa" aria-label="Profile: laputa">@<bdi>laputa</bdi></a><br />
Have you update the firmware on the Pytrack yet? It should be done first.</p>
<p dir="auto">Instructions are at:<br />
<a href="https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.html</a></p>
<p dir="auto">If you're on Windows you can use the DFU driver I posted: <a href="http://metavurt.net/software/drivers/PyTrack_DFU.zip" target="_blank" rel="noopener noreferrer nofollow ugc">http://metavurt.net/software/drivers/PyTrack_DFU.zip</a></p>
<p dir="auto">to skip the Zadig section and go straight to <code>dfu-util-static.exe -D pytrack_0.0.8.dfu</code></p>
]]></description><link>https://forum.pycom.io/post/14118</link><guid isPermaLink="true">https://forum.pycom.io/post/14118</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Thu, 04 Jan 2018 23:23:01 GMT</pubDate></item></channel></rss>
