cant tell if its a pysence or pytrack... upgrade failed'
 Just got new fipy and pytrack today.
 It shows up on the COM ports, is selectable by 'pycom firmware update'
 updater responds with "cant tell if its a pysence or pytrack. upgrade failed'Cant find anything on this issue, please advise.
 @jmarcelino said in cant tell if its a pysence or pytrack... upgrade failed': dfu-util-static.exe -D pytrack_0.0.8.dfu Thank you, the USB upgrade I was using was from an old post. Your zip process worked, and the upgrade was successful. Thanks
 @laputa
 Have you update the firmware on the Pytrack yet? It should be done first.Instructions are at:
 https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.htmlIf you're on Windows you can use the DFU driver I posted: http://metavurt.net/software/drivers/PyTrack_DFU.zip to skip the Zadig section and go straight to dfu-util-static.exe -D pytrack_0.0.8.dfu
