    WS2811 Usage
    python
    9 Posts 2 Posters 1.5k Views 2 Watching
    • M Offline
      misterlisty
      Any have experience with driving a Ws2811 IC ie used to drive a RGB LED.
      Apparently it uses NRZ code which is foreign to me.
        livius @misterlisty
        @misterlisty
        Do you mean WS2812 RGB with integrated WS2811 or WS2811 as separate IC?
        • M Offline
          misterlisty @livius
          @livius Yes i do
            livius @misterlisty
            @misterlisty
            May i ask why? if you have cheap integrated one?
            But i do not see the difference if you connect it same you got WS2812 ;-)
            And you can work with standard lib
            • M Offline
              misterlisty @livius
              @livius Thanks, not sure what you mean can work with standard lib? I want to add a RGB to the external of an enclosure so cannot use the builtin one on the module.
              How do i work with standard library?
                livius @misterlisty
                @misterlisty
                maybe we do not understand each other ;-)
                I do not say about integreated into pycom module (Heart beat LED)
                I am talking about WS2812 which is WS2811 IC + LED 5050.
                In your question is WS2811 not WS2812 and because of this i have asked
                If you try to drive RGB led(WS2812) strip use existed libs like:
                https://raw.githubusercontent.com/Gadgetoid/wipy-WS2812/master/ws2812alt.py
                M 2 Replies Last reply Reply Quote 0
                • M Offline
                  misterlisty @livius
                  @livius this looks like exactly what i'm looking for, will try it today.
                  • M Offline
                    misterlisty
                    • M Offline
                      misterlisty @livius
                      @livius I am using the separate ws2811 ic and i have tried your code and it appears not to work? The datasheets suggest different timings..can you suggest what i need to adjust? https://cdn-shop.adafruit.com/datasheets/WS2811.pdf
