    Pymakr to be used under openSuse
    pymakrinstallationopensuse
    2 Posts 1 Posters 1.1k Views 1 Watching
    • H Offline
      hjoe Pybytes Beta
      I'm using Suse since 20 years and don't like to switch.
      Currently only installation packages offered only for Debian or RedHat. Red Hat is using RPM packages which are generally useable for openSuse as well. So I tried to use the RPM
      pymakr-1.0.0.b6-1.noarch-1.rpm
      Unfortunately the is a prerequisite missing
      "nothing provides pyserial needed by pymakr-1.0.0.b6-1.noarch"
      I installed manually python-pyserial but this doesn't help.
      I hope someone has ideas how to solve this to get Pymakr running with openSuse.
      Thanks.
      • H Offline
        hjoe Pybytes Beta @hjoe
        I tried to install the missing things manually, see what happens when calling
        $ pymakr
        Python 2.7.12
        libpng warning: iCCP: known incorrect sRGB profile
        Warning: translation file 'eric6_de_DE'could not be loaded.
        Using default.
        BackgroundService listening on: 36250
        File "/usr/share/pymakr/modules/Utilities/BackgroundClient.py", line 193, in <module>
        backgroundClient.run()
        File "/usr/share/pymakr/modules/Utilities/BackgroundClient.py", line 178, in run
        'EXCEPTION', '?', [str(exctype), str(excval), tbinfo])
        File "/usr/share/pymakr/modules/Utilities/BackgroundClient.py", line 81, in __send
        self.connection.sendall(header)
        File "/usr/lib64/python2.7/socket.py", line 228, in meth
        return getattr(self._sock,name)(*args)
        socket.error: [Errno 32] Broken pipe
