Wipy 2.0 and BME280 sensor
Hello!
Was anybody able to use I2C BME280 sensor? It works flawlessly on Wipy 1.0 using a driver from Paul Cunnane (https://bitbucket.org/oscarBravo/wipy_bme280), but I get strange errors on Wipy 2.0:
>>> from machine import I2C >>> import bme280 >>> i2c = I2C(0, I2C.MASTER, baudrate=100000) >>> bme = bme280.BME280(i2c=i2c) Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/flash/lib/bme280.py", line 186, in __init__ File "/flash/lib/bme280.py", line 106, in write8 TypeError: object with buffer protocol requiredIt looks like this operation fails:
i2c.writeto_mem(0x76, 0xF4, 0x3F)I can see the device on I2C bus, so the wiring should be OK. I also have a HD44780 display with PCF8574 backpack connected to I2C bus and it works.
I am using the latest firmware 0.9.4b1.
One last thing - I am connected to Wipy via telnet (Putty) and the REPL is almost unusable. After few lines of code it hangs or key presses start to generate weird characters.
Michal
Hi, It works with my Wipy 2.0, i think the only change i made was:
def write8(self, register, value):
"""Write an 8-bit value to the specified register."""
value = value & 0xFF
self._i2c.writeto_mem(self._address, register, bytes([value]))
Hi michal,
Also try to use the bme280 sensor ( working with the wipy1 ok! ) but have the same errors with the wipy 2!
Had you resolve this ? If yes could you tell me how ?Best regards
Jiemde
@Baruch1966
Hi!Here is the repository with driver from Dave Hylands:
https://github.com/dhylands/python_lcdHere is the sample code:
from machine import I2C from i2c_lcd import I2cLcd i2c = I2C(0, I2C.MASTER, baudrate=100000) lcd = I2cLcd(i2c, 0x27, 4, 20) lcd.putstr("It Works!")I use this display: http://www.santy.cz/zobrazovace-c7/lcd-2004-blue-i2c-i9/
and this level converter: http://www.santy.cz/moduly-omezovacu-a-prevodniku-c34/i2c-uart-level-konvertor-3v-5v-4way-i223/Michal
@michal said in Wipy 2.0 and BME280 sensor:
I am using the latest firmware 0.9.4b1.Can you share a example code with PCF8574?
Hi Michal,
Thanks for the quick feedback, glad that it works now :-)
I got confused with I2C Quick Reference (https://docs.pycom.io/wipy2/2wipy/quickref.html#i2c-bus) which is the same for both versions of Wipy.
It's our fault, we need to make the API accept an integer as well. Will be fixed shortly.
Cheers,
Daniel
Hi Daniel!
I can confirm, that it works with bytes object:-)
>>> from machine import I2C >>> import bme280 >>> i2c = I2C(0, I2C.MASTER, baudrate=100000) >>> bme = bme280.BME280(i2c=i2c) >>> print(bme.temperature, bme.pressure, bme.humidity) 24.07C 967.63hPa 64.16%I got confused with I2C Quick Reference (https://docs.pycom.io/wipy2/2wipy/quickref.html#i2c-bus) which is the same for both versions of Wipy.
Thanks a lot for your help!
Michal
@michal when you do the
i2c.scan()are you able to see the sensor connected?TypeError: object with buffer protocol requiredThis error occurs because the function expects a
bytesobject and you are trying to send an integer. Could you try with:i2c.writeto_mem(0x76, 0xF4, bytes([0x3F]))?
Obviously we should make the drivers fully compatible with the old ones. We'll definitely fix it, but please try the workaround above to confirm the problem. Thanks.
Cheers,
Daniel
