    Lora: Documentation vs. Example code regards OTAA
    loraotaa
    23 Posts 5 Posters 6.4k Views 5 Watching
      robert-hh @ssmith
      @ssmith Yes, I'm using TTN. As far as I can could read, the limit is for downlink messages, from TTN to the node. Uplink, to TTN, I did not experience any limit.
        robert-hh @ssmith
        @ssmith Besides that, no luck. Simple device-to-device works, the power getting out of the antenna looks similar, with the FiPy a little bit (25% = 2 dB) stronger. But that may be within the setup-variation.
          asavvin
          Hello!
          I am having issue with activating using method otaa lopy with ttn gateway fot US915.
          whats correct code i should use I searched a lot of topics over weekend and could not find correct code.
          Thank you
          Same time using ttn node US915 with ttn gateway activation worked as shown.
          • 1
          • 2
          • 2 / 2
