lora.nvram example needed
 I've searched for some functioning example of lora.nvram and found none. Can someone send one ?
 It's absolutely needed for deepsleep function.
 I know this is an old post but for me this is still an issue.
 Any may of learning more about the specifics would be very much appreciated e.g what doespycom.nvs_get(key)return?
 Should I see somthing in the REPL?
 Example:>>> lora.nvram_save() >>> l= pycom.nvs_get('lora') >>> print(l) NoneAm I going about this in completely the wrong way?
 @luc-hanneuse did you manage to solve this issue.
 I have a similar problem.
 I have place the lora.nvram_restore() after my lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915) command. This seems like the logical place to put it.
 However after waking from sleep a few times, it appears that restore does not work correctly.I am also having problems making the app_eui and app_key available for use between different functions (def) within the same file/module. I am using global app_eui, app_key in both functions but I get an error after waking with app_eui undefined!!!! Any ideas?? Peter.
 @livius I also appreciate it when there comes a working example for the using of the nvram and restore function.
 Everybody at the forum is from do this but by the most of us it isn`t working either.
 @jcaron
 That's what I'm doing.It's just a bit illogical for me, I've to try 5 or 6 different codes to find a working one. The place of the lora.nvram_restore()isn't obvious ... If I place it just after thelora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)then it's not working !My working example : print("deepsleep prog") from network import LoRa import socket import binascii import struct import time import utime #utime init_timer = time.time() # Initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868) # create an ABP authentication params dev_addr = struct.unpack(">l", binascii.unhexlify('00 00 00 00'.replace(' ','')))[0] nwk_swkey = binascii.unhexlify('000000000000000000000000000000000') app_swkey = binascii.unhexlify('000000000000000000000000000000000') print("start join LoRa") print(utime.localtime())#utime print(utime.time())#utime # join a network using ABP (Activation By Personalization) lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey)) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) lora.nvram_restore() #strange place for the restore but working. # make the socket blocking # (waits for the data to be sent and for the 2 receive windows to expire) s.setblocking(True) while(True): print(".") # save the coordinates in a new variable coord = l76.coordinates() # verify the coordinates received if coord == (None, None) and time.time() < 200: print("Getting Location...") pycom.rgbled(0x7f7f00) #jaune print(utime.time())#utime continue # send the Coordinates to LoRA print("sending") pycom.rgbled(0x0000ff) #bleu s.send(struct.pack("<i", int(coord[0]*100000))+struct.pack("<i", int(coord[1]*100000))+struct.pack("<H", int(utime.time()))) time.sleep(1) lora.nvram_save() #nvram print("sent") print(time.time()) print(utime.localtime())#utime print(utime.time())#utime pycom.rgbled(0x000000) #sleep print("sleep") py.setup_sleep(600 - time.time()) py.go_to_sleep()If someone has something smarter with an ABP connection, help me.
 It's quite simple... When you boot, lora.nvram_restore(). Before you go to sleep,lora.nvram_save().
 @livius
 I read the documentation.
 I need a full example.I've a written a code and I tried to use those functions lora.nvram_save() and lora.nvram_restore() . But it doesn't seem to work. The "counter" of LoRaWan message reset.
 @luc-hanneuse said in lora.nvram example needed:
 alway look into official documentation. There is
 https://docs.pycom.io/chapter/firmwareapi/pycom/network/lora.html#loranvramsave
 https://docs.pycom.io/chapter/firmwareapi/pycom/network/lora.html#loranvramrestore
 https://docs.pycom.io/chapter/firmwareapi/pycom/network/lora.html#loranvrameraseif you need save some custom information use
 https://docs.pycom.io/chapter/firmwareapi/pycom/pycom.html#pycomnvssetkey-value
 https://docs.pycom.io/chapter/firmwareapi/pycom/pycom.html#pycomnvsgetkey
 https://docs.pycom.io/chapter/firmwareapi/pycom/pycom.html#pycomnvserasekey
