Downgrading firmware (advanced users)
Hello everyone,
We have recently updated our upgrade tool to simplify the procedure of performing a firmware downgrade. It can now be performed using either the GUI version of the tool, or the CLI version. The most upto date instructionsfor how to perform this can be found here: https://docs.pycom.io/chapter/advance/downgrade.html
We have made previous firmware versions available to download here:
Note: Prior to version
1.16.0.b1the firmware for modules with LoRa functionality was frequency specific. From1.16.0.b1and onward, the firmware is region agnostic and this can either be set programmatically or via the config block (see here)
@stefan85e
Please go to new topic this is really unreleated one
@stefan85e
Simple wire between or better breadboard and wire
but you done this already if you have custom TTL-UART connected
If I dont have a expansion board 1.0 or 2.0 how do I connect jumper connected between P2 and GND ?
