US915 OTAA - Cannot communicate with packet forwarder
Hi all,
i'd like to ask for some help to connect a lopy device to a packet forwarder running on a raspberry pi.
The frustrating part on this communication problem is that it's at the very beginning, the endpoint RF packets aren't arriving correctly into the gateway. I want to clarify that the endpoint and the gateway are separated by 10 cms, and both have antennas... impossible not to work because of that.I remember that a few months ago, the last time i worked on this project, each time the endpoint tried to communicate with the gateway it received the packets almost immediately. Now i check the packet forwarder console and i get a device message each 10 minutes.
Please help!
To give you some context:
os.uname()
(sysname='LoPy', nodename='LoPy', release='1.17.0.b1', version='v1.8.6-849-d0dc708 on 2018-02-27', machine='LoPy with ESP32', lorawan='1.0.2')LOPY CODE
from network import LoRa import socket import time import binascii # Initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915, frequency=903400000, bandwidth=LoRa.BW_500KHZ, power_mode=LoRa.ALWAYS_ON, public=True, sf=10) #remove all channels for channel in range(3, 72): lora.remove_channel(channel) lora.add_channel(4, frequency=903400000-300000, dr_min=0, dr_max=4) lora.add_channel(5, frequency=903400000-100000, dr_min=0, dr_max=4) lora.add_channel(6, frequency=903400000+100000, dr_min=0, dr_max=4) lora.add_channel(7, frequency=903400000+300000, dr_min=0, dr_max=4) # create an OTAA authentication parameters app_eui = binascii.unhexlify('AD A4 DA E3 AC 12 67 6B'.replace(' ','')) app_key = binascii.unhexlify('11 B0 28 2A 18 9B 75 B0 B4 D2 D8 C7 FA 38 54 8B'.replace(' ','')) # # join a network using OTAA (Over the Air Activation) lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0, dr=0) # wait until the module has joined the network while not lora.has_joined(): time.sleep(2.5) print('Not yet joined...') print('Joined!')packet forwarder 'global_conf.json'
{ "SX1301_conf": { "lorawan_public": true, "antenna_gain": 0, "clksrc": 1, "radio_0": { "enable": true, "freq": 902600000, "rssi_offset": -165, "tx_enable": true, "tx_freq_max": 928000000, "tx_freq_min": 902000000, "type": "SX1257" }, "radio_1": { "enable": true, "freq": 903400000, "rssi_offset": -165, "tx_enable": false, "type": "SX1257" }, "chan_FSK": { "enable": false, "radio": 0 }, "chan_Lora_std": { /* Lora MAC channel, 250kHz, SF7, 868.3 MHz */ "enable": true, "radio": 1, "if": -200000, "bandwidth": 250000, "spread_factor": 7 }, "chan_multiSF_0": { "enable": true, "if": -300000, "radio": 0 }, "chan_multiSF_1": { "enable": true, "if": -100000, "radio": 0 }, "chan_multiSF_2": { "enable": true, "if": 100000, "radio": 0 }, "chan_multiSF_3": { "enable": true, "if": 300000, "radio": 0 }, "chan_multiSF_4": { "enable": true, "if": -300000, "radio": 1 }, "chan_multiSF_5": { "enable": true, "if": -100000, "radio": 1 }, "chan_multiSF_6": { "enable": true, "if": 100000, "radio": 1 }, "chan_multiSF_7": { "enable": true, "if": 300000, "radio": 1 }, "lbt_cfg": { "enable": false, "nb_channel": 1, "rssi_target": 160, "scan_time_us": 5000, "start_freq": 869525000, "tx_delay_1ch_us": 4000000, "tx_delay_2ch_us": 4000000 }, "tx_lut_0": { "pa_gain": 0, "mix_gain": 8, "rf_power": -6, "dig_gain": 3 }, "tx_lut_1": { "pa_gain": 0, "mix_gain": 10, "rf_power": -3, "dig_gain": 3 }, "tx_lut_2": { "pa_gain": 0, "mix_gain": 12, "rf_power": 0, "dig_gain": 3 }, "tx_lut_3": { "pa_gain": 1, "mix_gain": 8, "rf_power": 3, "dig_gain": 3 }, "tx_lut_4": { "pa_gain": 1, "mix_gain": 10, "rf_power": 6, "dig_gain": 3 }, "tx_lut_5": { "pa_gain": 1, "mix_gain": 12, "rf_power": 10, "dig_gain": 3 }, "tx_lut_6": { "pa_gain": 1, "mix_gain": 12, "rf_power": 11, "dig_gain": 3 }, "tx_lut_7": { "pa_gain": 2, "mix_gain": 9, "rf_power": 12, "dig_gain": 3 }, "tx_lut_8": { "pa_gain": 1, "mix_gain": 15, "rf_power": 13, "dig_gain": 3 }, "tx_lut_9": { "pa_gain": 2, "mix_gain": 10, "rf_power": 14, "dig_gain": 3 }, "tx_lut_10": { "pa_gain": 2, "mix_gain": 11, "rf_power": 16, "dig_gain": 3 }, "tx_lut_11": { "pa_gain": 3, "mix_gain": 10, "rf_power": 20, "dig_gain": 3 }, "tx_lut_12": { "pa_gain": 3, "mix_gain": 11, "rf_power": 23, "dig_gain": 3 }, "tx_lut_13": { "pa_gain": 3, "mix_gain": 12, "rf_power": 24, "dig_gain": 3 }, "tx_lut_14": { "pa_gain": 3, "mix_gain": 13, "rf_power": 25, "dig_gain": 3 }, "tx_lut_15": { "pa_gain": 3, "mix_gain": 15, "rf_power": 26, "dig_gain": 3 } }, "gateway_conf": { "forward_crc_disabled": false, "forward_crc_error": false, "forward_crc_valid": true, "gateway_ID": "0102030405060708", "keepalive_interval": 12, "push_timeout_ms": 120, "serv_port_down": 1700, "serv_port_up": 1700, "server_address": "192.168.0.110", "stat_interval": 20, "synch_word": 52 } }
@jmarcelino said in US915 OTAA - Cannot communicate with packet forwarder:
LoRaWAN network server
Hi @jmarcelino. Thanks for your help.
I'm using the brocaar's one network server https://www.loraserver.io/I have copied below the docker-compose config file content:
version: "2" services: app: build: . expose: - "8090" ports: - "8090:8090" volumes: - .:/app depends_on: - gatewaybridge - loraserver - appserver - postgres - mosquitto - redis postgres: image: library/postgres:10.2 volumes: - ./db/pgdata:/pgdata ports: - "54322:5432" environment: - POSTGRES_PASSWORD=loraserver - POSTGRES_USER=loraserver - POSTGRES_DB=loraserver - PGDATA=/pgdata command: -p 5432 elasticsearch: image: elasticsearch:2.4 container_name: elasticsearch environment: - cluster.name=docker-cluster - bootstrap.memory_lock=true - "ES_JAVA_OPTS=-Xms512m -Xmx512m" ulimits: memlock: soft: -1 hard: -1 mem_limit: 1g volumes: - esdata1:/usr/share/elasticsearch/data ports: - 9200:9200 # # STARTS BROCAAR SERVERS # loraserver: image: loraserver/loraserver environment: - DB_AUTOMIGRATE=true - LOG_NODE_FRAMES=true - NET_ID=010203 - BAND=US_902_928 - REDIS_URL=redis://redis:6379 - GW_MQTT_SERVER=tcp://mosquitto:1883 - GW_SERVER_JWT_SECRET=verysecret - POSTGRES_DSN=postgres://loraserver_ns:loraserver_ns@postgresql_ns/loraserver_ns?sslmode=disable - JS_SERVER=http://appserver:8003 appserver: image: loraserver/lora-app-server ports: - 8080:8080 environment: - DB_AUTOMIGRATE=true - REDIS_URL=redis://redis:6379 - POSTGRES_DSN=postgres://loraserver_as:loraserver_as@postgresql_as/loraserver_as?sslmode=disable - MQTT_SERVER=tcp://mosquitto:1883 - JWT_SECRET=verysecret - HTTP_TLS_CERT=/etc/lora-app-server/certs/http.pem - HTTP_TLS_KEY=/etc/lora-app-server/certs/http-key.pem - AS_PUBLIC_SERVER=appserver:8001 gatewaybridge: ports: - 1700:1700/udp image: loraserver/lora-gateway-bridge environment: - MQTT_SERVER=tcp://mosquitto:1883 postgresql_ns: image: postgres:9.6-alpine ports: - 5432 environment: - POSTGRES_PASSWORD=loraserver_ns - POSTGRES_USER=loraserver_ns - POSTGRES_DB=loraserver_ns postgresql_as: image: postgres:9.6-alpine ports: - 5432 environment: - POSTGRES_PASSWORD=loraserver_as - POSTGRES_USER=loraserver_as - POSTGRES_DB=loraserver_as redis: ports: - 6379 image: redis:4-alpine mosquitto: ports: - 1883:1883 image: eclipse-mosquitto volumes: esdata1: driver: localThen, once the docker servers are running I config the lorawan platform through the web admin ui like this:
Device profile
Service profile
Gateway configuration
Not sure if that's enough @jmarcelino . Let me know if you need some extra data.
Thanks!
Hi @pablocaviglia,
I think I can see some problems with that channel (frequency) configuration, but let me ask first what is the LoRaWAN network server you're using and more importantly what is the channel map it is expecting?
Hey @seb, thx for your rapid response.
I followed your advice of separate the gateway and the endpoint, they are like 3 meters away from each other but still no luck. I'll try to continue configuring the lopy with different values and see what happens.I'll keep this thread up to date if i find a solution.
Thx!
Pablo Caviglia
My first advice would be to try separating the nodes more than 10cm. It is possible for the receiver to be swamped by the incoming signal and not be able to understand it. If increasing the separation doesn't help we can look into it further.
