    Reading a bluetooth characteristic value on an Iphone
    lopy blecharacteristicsread function
    1 Posts 1 Posters 673 Views 1 Watching
      johnallen24
      I am trying to read the characteristic value from the LoPy on an Iphone with the example code from the Pycom documentation.
      from network import Bluetooth
      bluetooth = Bluetooth()
      bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890123456')
      def conn_cb (bt_o):
      events = bt_o.events()
      if events & Bluetooth.CLIENT_CONNECTED:
      print("Client connected")
      print("Client disconnected")
      bluetooth.advertise(True)
      srv1 = bluetooth.service(uuid=b'1234567890123456', isprimary=True)
      chr1 = srv1.characteristic(uuid=b'ab34567890123456', value=5)
      char1_read_counter = 0
      def char1_cb_handler(chr):
      global char1_read_counter
      char1_read_counter += 1
      events = chr.events()
      if  events & Bluetooth.CHAR_WRITE_EVENT:
          print("Write request with value = {}".format(chr.value()))
          if char1_read_counter < 3:
              print('Read request on char 1')
              return 'ABC DEF'
      char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char1_cb_handler)
      I can get the phone to connect to the LoPy and receive the characteristic data from it. However, I cannot figure out how to read the data to get the characteristic's value of 5. I am using Xcode with the Swift programming language and its Core Bluetooth framework. When reading a value on the LoPy, there is a simply a read() function. How does this function work and is there a way to get the code behind it, so I could set up a similar implementation in Swift?
