Unable to install Pymakr 1.2.10 in Atom 1.25.0
  • Hi there, i still having problem on install the Pymakr plugin version 1.2.10 with the Atom version 1.25.0.
    Windows 8.1
    Atom 1.25.0
    Pymakr 1.2.10
  • @seb
    Thanks. Did the trick. Remove directory, reinstall and rebuild the package
    Thx,
    Geert
  • @gedp
    if you previously had pymakr installed can you try deleting the /Users/gedp/.atom/packages/pymakr/ directory and re-installing pymakr
  • Hi,
    Tried installing pymakr plugin on Atom 1.25.0 but plugin shows as incompatible package:
    Some installed packages could not be loaded because they contain native modules that were compiled for an earlier version of Atom.
    serialport@4.0.6 – The module '/Users/gedp/.atom/packages/pymakr/node_modules/serialport/build/Release/serialport.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 53. This version of Node.js requires NODE_MODULE_VERSION 54. Please try re-compiling or re-installing the module (for instance, using npm rebuild ornpm install).
  • @mj said in Unable to install Pymakr 1.2.10 in Atom 1.25.0:
    Windows 8.1
    Atom 1.25.0
    Pymakr 1.2.10
    Seriously, if you are using Windows @MJ try Visual Studio Code (https://code.visualstudio.com/) much more reliable than Atom for developing with Pycom products, especially noting some of the other posts about Atom lately.
  • @mj It looks like atom is not able to connect to the internet correctly. Please double check your internet setting and any proxy settings you might be using in atom.
