<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New firmware release v1.17.3.b1]]></title><description><![CDATA[<p dir="auto">Hello everyone,</p>
<p dir="auto">This release is mainly here to fix some problems introduced by 1.17.2.b1 a few days ago.<br />
Here's the change log:</p>
<ul>
<li>esp32: Switch off the heartbeat LED right after boot.</li>
<li>esp32/ftp/updater.c: updated function updater_write_boot_info() to write encrypted header (if flash encryption enabled)</li>
<li>esp32/ftp/updater.c: removed code which checked in ota_write() if chunks are multiple of 16 bytes</li>
<li>esp32: Use esp_timer_get_time instead of gettimeofday inside ISRs and the idle task (as recommended by Espressif). Fixes crashes caused when using time.ticks_ms() and ticks_us()</li>
<li>esp32: Only create the LTE task once. Fixes soft reset for the FiPy and GPy.</li>
<li>esp32: Correct the heartbeat behaviour during soft reset.</li>
</ul>
<p dir="auto">Please note that that the function <code>ticks_cpu</code> (<a href="https://docs.pycom.io/chapter/firmwareapi/micropython/utime.html#utimetickscpu" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.pycom.io/chapter/firmwareapi/micropython/utime.html#utimetickscpu</a>) has been changed and it now returns a value in microseconds (it's useless to return nano-seconds anyway), so it can be seen as another version of ticks_us but a lot faster. The nano-gateway example has been updated to use this function instead: <a href="https://github.com/pycom/pycom-libraries/commit/f344b5a4ac220d1c960260d80cdde07ce623bc23" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/pycom/pycom-libraries/commit/f344b5a4ac220d1c960260d80cdde07ce623bc23</a></p>
<p dir="auto">Cheers,<br />
Daniel</p>
]]></description><link>https://forum.pycom.io/topic/2875/new-firmware-release-v1-17-3-b1</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 19:14:46 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2875.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Mar 2018 18:33:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Sat, 12 May 2018 08:11:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daniel" aria-label="Profile: daniel">@<bdi>daniel</bdi></a> Hi, i have a LoPy4 with firmware 1.17.3.b1 attached to a Expansionboard v2.1A. I have a code that worked fine on SiPy, but after transfer to LoPy4 i get this error.<br />
Note: this error comes with or without any pins connected to the expansionboard.<br />
If you want the <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a>, please provide me with a mail i can sent to.<br />
Thank you</p>
<p dir="auto">UPDATE: This is solved by disable wifi on boot <code>pycom.wifi_on_boot(False)</code><br />
See topic: <a href="https://forum.pycom.io/topic/3217/lopy4-guru-meditation-error">https://forum.pycom.io/topic/3217/lopy4-guru-meditation-error</a></p>
<pre><code>Guru Meditation Error: Core  0 panic'ed (InstrFetchProhibited)
. Exception was unhandled.
Register dump:
PC      : 0x00000000  PS      : 0x00060630  A0      : 0x8011855d  A1      : 0x3ffbd650
A2      : 0x00000000  A3      : 0x00000037  A4      : 0xffffffa2  A5      : 0x3fbc0af0
A6      : 0x00000008  A7      : 0x00000000  A8      : 0x8012382c  A9      : 0x3ffbd640
A10     : 0x3fbc0b0c  A11     : 0x00000037  A12     : 0xffffffa2  A13     : 0x3ffbd6e4
A14     : 0x7777395d  A15     : 0x7777395d  SAR     : 0x00000010  EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000  LBEG    : 0x4009b351  LEND    : 0x4009b385  LCOUNT  : 0xffffffff
Backtrace: 0x00000000:0x3ffbd650 0x4011855a:0x3ffbd670 0x40119567:0x3ffbd740 0x4012faf5:0x3ffbd760 0x40131657:0x3ffbd7b0```</code></pre>
]]></description><link>https://forum.pycom.io/post/19448</link><guid isPermaLink="true">https://forum.pycom.io/post/19448</guid><dc:creator><![CDATA[bjsi9]]></dc:creator><pubDate>Sat, 12 May 2018 08:11:09 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Fri, 23 Mar 2018 15:00:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daniel" aria-label="Profile: daniel">@<bdi>daniel</bdi></a> the function wlan.isconnected() does not recognize that the access point are shutted down and the connection are falling. if i need to do something when the connection goes down i can't. I had reported the same issue in the release v1.16.0.b1.</p>
]]></description><link>https://forum.pycom.io/post/17608</link><guid isPermaLink="true">https://forum.pycom.io/post/17608</guid><dc:creator><![CDATA[p3pp3d0m]]></dc:creator><pubDate>Fri, 23 Mar 2018 15:00:29 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Fri, 23 Mar 2018 13:56:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shishir" aria-label="Profile: shishir">@<bdi>shishir</bdi></a> Yes, I run the gateway example code from my branch, and that works fine so far. Using the gateway example code from the pycom lib may fail, because it is just a little bit too late. Here is the code I'm using:<br />
<a href="https://github.com/robert-hh/pycom-libraries/blob/nanogateway/examples/lorawan-nano-gateway/nanogateway.py" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/robert-hh/pycom-libraries/blob/nanogateway/examples/lorawan-nano-gateway/nanogateway.py</a><br />
That is still more a hack than a fix. But a fix would have to be deep down in the LoRa Stack and would have to schedule downlink messages there.</p>
]]></description><link>https://forum.pycom.io/post/17606</link><guid isPermaLink="true">https://forum.pycom.io/post/17606</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 23 Mar 2018 13:56:34 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Fri, 23 Mar 2018 13:46:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-hh" aria-label="Profile: robert-hh">@<bdi>robert-hh</bdi></a> Is the LoRawan Nano gateway example working with OTAA ? Are you running your branch code for nanagateway?</p>
]]></description><link>https://forum.pycom.io/post/17605</link><guid isPermaLink="true">https://forum.pycom.io/post/17605</guid><dc:creator><![CDATA[shishir]]></dc:creator><pubDate>Fri, 23 Mar 2018 13:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Fri, 23 Mar 2018 15:42:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daniel" aria-label="Profile: daniel">@<bdi>daniel</bdi></a> +++++ It looks like this version is stable. No crash on two devices running this version since 4 days. Before, it would have failed within that time. No proof, but  a strong indication.</p>
]]></description><link>https://forum.pycom.io/post/17602</link><guid isPermaLink="true">https://forum.pycom.io/post/17602</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 23 Mar 2018 15:42:25 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Wed, 21 Mar 2018 14:16:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-hh" aria-label="Profile: robert-hh">@<bdi>robert-hh</bdi></a></p>
<p dir="auto">not on my FiPy+PyTrack combo.</p>
<p dir="auto">I have to manually enable it at REPL ...</p>
<p dir="auto">Also, I sometimes got it to crash ... not often, but sometimes after an code-upload xor machine.reset() followed by pycom.heartrate(True) ... it crashes ...</p>
<p dir="auto">MicroPython v1.8.6-849-83e2f7f on 2018-03-19; FiPy with ESP32<br />
Type "help()" for more information.</p>
<blockquote>
<blockquote>
<blockquote>
<p dir="auto">pycom.heartbeat(True)<br />
Guru Meditation Error: Core  1 panic'ed (LoadProhibited)<br />
. Exception was unhandled.<br />
Register dump:<br />
PC      : 0x4008e53b  PS      : 0x00060033  A0      : 0x8008ce5d  A1      : 0x3ffc1370<br />
A2      : 0x3ffd6f34  A3      : 0x00060023  A4      : 0x3ffc541c  A5      : 0x00000001<br />
A6      : 0x000000fe  A7      : 0x3f401f69  A8      : 0x00000000  A9      : 0x3ffd6f34<br />
A10     : 0x3ffd6f34  A11     : 0x00000000  A12     : 0x800de215  A13     : 0x3ffdbff0<br />
A14     : 0xffffffff  A15     : 0x3f401f69  SAR     : 0x00000003  EXCCAUSE: 0x0000001c<br />
EXCVADDR: 0x00000004  LBEG    : 0x4009b661  LEND    : 0x4009b671  LCOUNT  : 0xffffffff</p>
</blockquote>
</blockquote>
</blockquote>
<p dir="auto">Backtrace: 0x4008e53b:0x3ffc1370 0x4008ce5a:0x3ffc1390 0x4008ba0d:0x3ffc13b0 0x400874bd:0x3ffc13d0 0x40083685:0x3ffc1410 0x400e1b65:0x00000000</p>
<p dir="auto">================= CORE DUMP START =================<br />
...<br />
...<br />
================= CORE DUMP END =================</p>
]]></description><link>https://forum.pycom.io/post/17500</link><guid isPermaLink="true">https://forum.pycom.io/post/17500</guid><dc:creator><![CDATA[combaindeft]]></dc:creator><pubDate>Wed, 21 Mar 2018 14:16:46 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Wed, 21 Mar 2018 06:26:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/combaindeft" aria-label="Profile: combaindeft">@<bdi>combaindeft</bdi></a> Actually the blue heartbeat is pulsing. Just the green light boot indicator is switched off immediately after boot.</p>
]]></description><link>https://forum.pycom.io/post/17461</link><guid isPermaLink="true">https://forum.pycom.io/post/17461</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Wed, 21 Mar 2018 06:26:36 GMT</pubDate></item><item><title><![CDATA[Reply to New firmware release v1.17.3.b1 on Wed, 21 Mar 2018 05:52:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daniel" aria-label="Profile: daniel">@<bdi>daniel</bdi></a> said in <a href="/post/17367">New firmware release v1.17.3.b1</a>:</p>
<blockquote>
<p dir="auto">esp32: Switch off the heartbeat LED right after boot.</p>
</blockquote>
<p dir="auto">Why did you by default switch of the heartbeat LED?</p>
<p dir="auto">It's a good thing to have on by default, as when we are trying to test new things  ... and things don't work, it's good to know that we'll always have a heartbeat if the device boot up.</p>
<p dir="auto">Also tried to set the pycom.heartbeat_on_boot(True) .... to try to enable on our boards that it should be on by default ...</p>
<p dir="auto">Though it looks like even that is not working, and your default off is doing a hard overwrite.</p>
<p dir="auto">Atleast, if you go set default to pycom.heartbeat(False)</p>
<p dir="auto">allow us individually to override it with: pycom.heartbeat_on_boot(True)</p>
<p dir="auto">Cheers.</p>
]]></description><link>https://forum.pycom.io/post/17456</link><guid isPermaLink="true">https://forum.pycom.io/post/17456</guid><dc:creator><![CDATA[combaindeft]]></dc:creator><pubDate>Wed, 21 Mar 2018 05:52:29 GMT</pubDate></item></channel></rss>
