    [Solved] Trying to run command exactly at :00, :15, :30 and :45 (every 15mins)
    Scheduled Pinned Locked Moved Projects
    pysensetimewipy2.0question
    9 Posts 3 Posters 2.2k Views 3 Watching
    • B Offline
      bmueller77
      Hi There,
      for my first WiPy-project i'd like to send a MQTT Message (temperature, etc.) from my WiPy 2.0 with Pisense-Board at exactly :00, :15, :30 and :45 to prevent time offsets over time. Actually my idea is, to run my main script, which connects to Wifi, collects data from sensors which actually takes 30-40 seconds. Time differs especially at Wifi reconnect. So i want to do a deepsleep for 13 minutes, then wait until full, half or quarter hours are reached to go on with the script but i do not have a clue, how to script this. Thanks in advance for your help.
      Best Regards
      bmueller
        jcaron @bmueller77
        @bmueller77 before addressing your question, a remark: if your WiPy is awake 1 or 2 minutes out of 15, you are going to have limited battery life. Not even counting your sensors, your average current is going to be somewhere between 3 and 7 mA, which would drain a relatively large 2500 mAh battery in about 2 to 5 weeks.
        Next, what exactly needs to be synchronised? Getting the data from the sensors, or actually sending the data?
        You will have to do an NTP syne after you wake up and connect to WiFi to get a precise time. You can then simply sleep for the difference between the time you want and the current time.
        • B Offline
          bmueller77
          • B Offline
            bmueller77 @jcaron
            @jcaron
            Hi, thanks for the remark. I'll plan to wake the WiPy as short as possible and/or maybe just wake it all 30 minutes.
            Well, it's not necessary for me to send the data in exact 15min cycles but i want to prevent a growing offset. As WiFi connection takes different times, there could be an offset of up to 30 seconds per hour. I just want to make sure, that these time differences will be automatically corrected.
            • B Offline
              bmueller77
              Took a while but i made it. For other users, here's the code
              from machine import RTC
              rtc = RTC()
              rtc.ntp_sync("78.46.52.71",15)
              while rtc.synced() != True:
              rtc.now()
              go = 0
              runeveryxseconds = 900 #intervall waiting for (here every 15 minutes)
              while go == 0:
                  t = rtc.now()
                  minute = '{:02d}'.format(t[4])
                  second = '{:02d}'.format(t[5])
                  tstamp = ((int(minute) * 60) + int(second) + 3600)
                  print("Time to launch: " + str(runeveryxseconds - tstamp % runeveryxseconds))
                  if tstamp % runeveryxseconds == 0:
                      go = 1
                      go = 0
                  time.sleep(0.8)
                jcaron @bmueller77
                @bmueller77 Depending on your exact needs, you could directly sleep for the remaining time instead of looping...
                • B Offline
                  bmueller77 @jcaron
                  @jcaron
                  I am reading sensor data from Pysense and sending them via MQTT, then i do
                  machine.deepsleep(873000)
                  machine.reset()
                  I added the reset because sometimes, the WiPy did not start the loop after waking up.
                    livius @bmueller77
                    @bmueller77 said in [Solved] Trying to run command exactly at :00, :15, :30 and :45 (every 15mins):
                    what do you mean here?
                    Deepsleep is like reset your whole script start from beggining (after time end).
                    It never back from point where you have finished
                    • B Offline
                      bmueller77 @livius
                      @livius Hi. I have the issue, that the device does not start again after several cycles. That was a try to fix it...
                      Update: Fixed the issue using WDT :-)
