    Disable DC-DC 3.3v
    deepsleepsd carddc-dccurrent drain
    5 Posts 4 Posters 1.2k Views 4 Watching
    • R Offline
      Roqueton
      Is it possible to disable the 3.3v regulator during deepsleep mode?. I have a current drain when a microSD is inserted and deepsleep mode is activated (around 5mA), because it is powered by 3.3v pin. If the SD is removed, the current drain stops (20uA).
      I am using a Wipy3 with lastest firmware and expansion board 2.1.
      Any ideas?
        jmarcelino @Roqueton
        @roqueton
        It's not possible, sorry. As you have found the microSD card slot is always powered.
          livius @jmarcelino
          then it is another design bug?
          G 1 Reply Last reply Reply Quote 2
          • R Offline
            Roqueton
            Thanks for the information.
            However, in my opinion, the control of the 3.3V Dc pin should be a important feature included in the Pycom device. My design sources several sensors using the 3.3V and, obviously, the current drained in deep sleep mode makes difficult the power autonomy.
            I have shorcutted the problem using a PNP transistor BCW68 and a 3,9K resistor in its base. It is controlled by a GPIO Pin. The emissor Pin goes to the WiPy 3.3v Pin and collector Pin is connected to the sensors and the SD card.
              gregcope @livius
              @livius Agreed. I was going to use an SD Card to store config, state and logs, but now my device is no longer low power...
              Seems a bit off when you can switch all (that I know of) bit off.
