DS18B20 not working in WiPy 2.0
  • Hello There
    I have copied and paste following code
    from machine import Pin
    from ds18x20 import DS18X20
    d=DS18X20(Pin((Pin.exp_board.G23, mode=Pin.OUT)))
    result=d.read_temps()
    print(result)
    The only difference is that I am using the WyPy expansion board. it throwing following error in Atom
    File "<stdin>", line 28
    SyntaxError: invalid syntax
    Line 28 is
    any ideas?
    Cheers
    Colombian1976
  • @colombianaus said in DS18B20 not working in WiPy 2.0:
    d=DS18X20(Pin.exp_board.G23, mode=Pin.OUT)
    now you miss Pin class...
    d=DS18X20(Pin(Pin.exp_board.G23, mode=Pin.OUT))
  • @seb
    hey mate,...
    OK so all code below, but as you can notice first 24 lines are commented. Furthermore, I have deleted extra parentheses for the line
    it now throws following error:
    File "<stdin>", line 28, in <module>
    TypeError: function does not take keyword arguments
    line 28 is
    import onewire, ds18x20
    the device is on GPIO23, expansion board
    dat = Pin(Pin.exp_board.G23, mode=Pin.OUT)
    create the onewire object
    ds = ds18x20.DS18X20(onewire.OneWire(dat))
    scan for devices on the bus
    roms = ds.scan()
    print('found devices:', roms)
    loop 10 times and print all temperatures
    for i in range(10):
    print('temperatures:', end=' ')
    ds.convert_temp()
    time.sleep_ms(750)
    for rom in roms:
    print(ds.read_temp(rom), end=' ')
    print()
    print(result)
    Thank you for your assistance mate
    Cheers
    Wilson
  • First thing I notice is that you are passing Pin a tuple:
    I think you have used one too many pairs of parentheses.
    Secondly, can you share all your code? because the code you posted is only 5 lines long but the error says line 28
