Debugging on the LoPy
I have an issue here with some code and would like to debug it.
Is there a way to debug on the LoPy?OSError('Network card not available',) Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 400d79cb PS : 00060330 A0 : 800ea3f8 A1 : 3ffdd380 A2 : 3ffb6370 A3 : 00000000 A4 : 00000001 A5 : 00000001 A6 : 00000000 A7 : 3ffd8828 A8 : 00000000 A9 : 00000000 A10 : 3ffb6370 A11 : 00060f23 A12 : 00060f20 A13 : b33f0000 A14 : 0000000a A15 : 3ffec1a0 SAR : 00000006 EXCCAUSE: 0000001c EXCVADDR: 00000044 LBEG : 4000c46c LEND : 4000c477 LCOUNT : 00000000 CPU halted.
Python has a debugger , which is available as a module called pdb . It supports setting conditional breakpoints , stepping through the source code one line at a time, stack inspection, and more.
import pdb msg = "this is a test" pdb.set_trace() print(msg)Insert pdb.set_trace() anywhere and it will function as a breakpoint . When you execute the script by python test.py, you will in the debug mode.
@daniel Here you go, courtesy of print-based debugging and tenacity:
https://github.com/pycom/pycom-micropython/issues/31
https://github.com/pycom/pycom-micropython/issues/32
While I have your attention, please reopen...
Feature Request: Good debugging story!
This is already on our wish list, to add a MicroPython debugger to Pymakr :-)
But anyway, for the kind of crash that you are experiencing, the only way to find the root cause is to debug it at C level.
@daniel Looks like I have got a steep learning curve ahead of me. :-( Can a JTAG debugger then be queried by the Python debugger, or are we strictly in C mode?
I will try. Have to use logging then to track it down. Might take a few days. I will file my results on GH and cross-link forum and issue for your reference.
@betabrain there's a way to connect a JTAG debugger and launch GDB, but it's not for the faint of heart ;-)
Can you share the steps to reproduce it? Thanks.
