    LORA NanoGateway (RAW) and MQTT publish ? disconnected
    lora lopydisconnectedmqttpublishwifi fails
    4 Posts 2 Posters 1.2k Views 2 Watching
      siejak
      HI
      I would like to use my Lopy as NanoGateway with Lora RAW and send all the received packages over MQTT to an online Broker.
      import struct
      from network import LoRa
      from network import WLAN
      import ufun
      # A basic package header
      # B: 1 byte for the deviceId
      # B: 1 byte for the pkg size
      # B: 1 byte for the messageId
      # %ds: Formated string for string
      _LORA_PKG_FORMAT = "!BBB%ds"
      # A basic ack package
      # B: 1 byte for the Ok (200) or error messages
      _LORA_PKG_ACK_FORMAT = "BBBB"
      # Open a Lora Socket, use rx_iq to avoid listening to our own messages
      lora = LoRa(mode=LoRa.LORA, rx_iq=True, frequency=864500000, sf=12)
      lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
      lora_sock.setblocking(False)
      broker_addr = "m23.cloudmqtt.com"
      #broker_addr = "test.mosquitto.org"
      MYDEVID = "PMdev"
      wlan = WLAN(mode=WLAN.STA)
      wlan.antenna(WLAN.INT_ANT)
      wlan.connect("wifiwasdeleted", auth=(WLAN.WPA2, "passwordwasdeleted"), timeout=5000)
      def settimeout(duration):
         pass
      while not wlan.isconnected():
           machine.idle()
      print("connected to WIFI")
      client = MQTTClient(MYDEVID, broker_addr, user="userwasdeleted", password="passwordwasdeleted", port=portwaschanged)
      client.settimeout = settimeout
      client.connect()
      print('Sending messages...')
          #LORA SETUP
          # Since the maximum body size in the protocol is 255 the request is limited to 512 bytes
          recv_pkg = lora_sock.recv(512)
          # If at least a message with the header is received process it
          if (len(recv_pkg) > 3):
              print("Package received")
              recv_pkg_len = recv_pkg[1]
              # If message is corrupted should not continue processing
              if (not len(recv_pkg) == recv_pkg_len + 3):
                  #continue
                  break
                  # Unpack the message based on the protocol definition
                  device_id, pkg_len, msg_id, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
                  print(device_id)
                  print(msg)
                  # Respond to the device with an acknoledge package
                  time.sleep(0.50)
                  ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, msg_id, 200)
                  #print(ack_pkg)
                  lora_sock.send(ack_pkg)
                  # publishing the data
                  client.publish(MYDEVID+'/value', str(msg))
                  print("sent ack")
      It's all working quite well but after about 4 hours the gateway is not forwarding any data to Mqtt broker. Is there any possibility to reconnect to Wifi after it has been disconnected? Thanks for help :)
        livius @siejak
        @siejak said in LORA NanoGateway (RAW) and MQTT publish ? disconnected:
        Simply do what you have done at start of the script - connect once again.
        I make connection and configuration of wifi as procedure it then is simply as e.g. connectToRouter() and if i got socket send error then i try reconnect to wifi by run the proc.
          siejak @livius
          @livius Hi
          Thanks for this quick response. Im quite new to micro-python :) How do I get the socket send error ? Could you give me a quick example what I need to write. Thank you.
            livius @siejak
            @siejak
            simple use e.g.:
            try:
                 s.send(data)
            except:
                connectToRouter()
