    Not correctly decoding USRP data
    lopy lora
    3 Posts 2 Posters 785 Views 2 Watching
    • N Offline
      nilam
      I tried to send message 'Hello' from USRP, but LoPy LoRa not decoding it correctly.
      it receive some garbage data. What can i do to receive it correctly?
        jcaron @nilam
        @nilam without any further details of what you set up on both sides, it’s going to be extremely difficult for anyone to help you...
        • N Offline
          nilam @jcaron
          @jcaron Thank you for reply, Sorry for giving less details.
          I am sending 'Hello mitcoe' message from file source as well as socket using USRP hardware and GNURadio (Matt- Gr-LoRa)
          Parameters :
          Frequency: 868MHz
          SF: 8
          Code rate: 4
          BW: 250KHz
          Sampling Rate: 250 KHz
          Header: True
          and same parameters on LoPy LoRa node.
          But i receive on LoPy LoRa some things like this
          Received data:
          1 b'\xe7\xe7+\xfa\x00MB'
          2 ��+�MB
          3 b'e7e72bfa004d42'
          Rx_cnt:1
          (rx_timestamp=676924426, rssi=-98, snr=0.0, sfrx=8, sftx=0, tx_trials=0)
          Received data:
          1 b'\xe7\xe7\xeb\xfa\x00MB'
          2 ����MB
          3 b'e7e7ebfa004d42'
          Rx_cnt:2
          (rx_timestamp=677851000, rssi=-98, snr=0.0, sfrx=8, sftx=0, tx_trials=0)
          My LoPy code to receive data is:
          print("In Receive Mode")
          s.setblocking(False)
          data = s.recv(64)
          if(data):
          print("Received data: "+"\n1",data)
          print ("2",data.decode('utf-8'))
          print("3",binascii.hexlify(data))
          i+=1
          rx2tx_data = 'Rx_cnt:'+str(i)
          print(rx2tx_data)
          print(lora.stats())
          I am not able to receive what i sent.
          Also i am sending message multiple times but lora only receives twice or thrice.
