    lopy received data into text conversion
    lopy lora
    10 Posts 3 Posters 1.3k Views 3 Watching
    • N Offline
      nilam
      how to convert lopy lora received data into text.
      • sebS Offline
        seb
        We are going to need more details about the format of the incoming data before we can help you out
        • N Offline
          nilam @seb
          @seb Thank you for reply.
          I am receiving 'Hello mitcoe' message from USRP B200 in gnuradio by using matt gr lora transmitter with udp socket source.
          • sebS Offline
            seb
            @nilam said in lopy received data into text conversion:
            matt gr lora
            Are you using LoRaWAN or raw LoRa?
            • N Offline
              nilam @seb
              @seb Raw LoRa
              @seb when i send using UDP socket, i dont receive anything.
              but when i send using file souce with 'Hello mitcoe' at hundreds of lines, it receives some things like this
              Received data:
              b'\xed\xe7\xe1\xfe\x00MB'
              • N Offline
                nilam
                • sebS Offline
                  seb @nilam
                  @nilam
                  Can you share your code so I can get a better understanding of what is going on
                    jcaron
                    You may want to check if changing rx_iq helps.
                    • N Offline
                      nilam @seb
                      @seb import ubinascii
                      from network import LoRa
                      from machine import Pin
                      lora = LoRa(mode=LoRa.LORA, frequency=868000000, tx_power=14, bandwidth=LoRa.BW_250KHZ, sf=8, preamble=8, coding_rate=LoRa.CODING_4_8, power_mode=LoRa.ALWAYS_ON, tx_iq=False, rx_iq=False, adr=True, public=True, tx_retries=1, device_class=LoRa.CLASS_A)
                      s.setblocking(False)
                      data = s.recv(64)
                      if(data):
                      print("Received data: "+"\n1",data)
                      print ("2",data.decode('utf-8'))
                      print("3",ubinascii.hexlify(data))
                      • N Offline
                        nilam @jcaron
                        @jcaron Rx_iq set to False. if i set it True, lopy does not receive any data.
                        how can i set sampling rate?
