    Pin mappings between GPy and Expansion board 2.0
    gpyi2c
    3 Posts 2 Posters 814 Views 2 Watching
      sprasad
      I'm working on I2C with GPy. Which pins on the expansion boards do I have to use for SDA and SCL? Also, I'm aware that I can also define SDA and SCL pins of my choice and use them. But as I observe, definitions are in terms of Px and port numbers on Expansion board are in terms on Gx. Where can I find the mapping between port numbers of my GPy and Expansion board?
      sebS 1 Reply Last reply Reply Quote 1
      • sebS Offline
        seb @sprasad
        @sprasad
        You can specify pins using the GXX number directly like so:
        p = Pin(Pin.exp_board.G16, mode=Pin.OUT)
        If you want to use Pxx numbers in your code, just compare the expansion board pinout diagram and the module pinout diagram to see how they map
          sprasad
          That worked! Thank you..
