    [SOLVED] OTA Not Working
    ota
    3 Posts 2 Posters 664 Views 2 Watching
      JuanMa
      Hi all,
      I am trying to use OTA Wifi following the documentation, but when the device requests the manifest, an error ocurrs:
      File "OTA_server.py", line 156, in do_GET
          manifest = generate_manifest(current_ver, host)
        File "OTA_server.py", line 287, in generate_manifest
          to_delete, new_files, to_update = get_diff_list(current_ver, latest)
        File "OTA_server.py", line 215, in get_diff_list
          right_paths = get_all_paths(right, ignore=ignore)
        File "OTA_server.py", line 201, in get_all_paths
          paths += [os.path.join(d, f) for f in files]
        File "OTA_server.py", line 201, in <listcomp>
        File "/usr/lib/python3.5/posixpath.py", line 89, in join
          genericpath._check_arg_types('join', a, *p)
        File "/usr/lib/python3.5/genericpath.py", line 143, in _check_arg_types
          (funcname, s.__class__.__name__)) from None
      TypeError: join() argument must be str or bytes, not 'NoneType'
      I have followed it and the problem seems to be that the method os.walk(path) returns None as dirpath. Am I doing something wrong?
      PD: The files inside the script folder are these:
      ServerFiles-->
                     OTA_Server.py
                     firmware_1.0.0.bin
                     firmware_1.0.1.bin
      Thanks,
      JuanMa
        JuanMa
        Problem solved. It is mandatory to create the version folders.
        • R Offline
          railmonitor @JuanMa
          @JuanMa I am currently trying the same, also referencing this video from Pycom: https://www.youtube.com/watch?v=NnUVYIedl_w
          When i run the HTTP server from the OTA folder in pycom-libraries-master/examples/OTA the folders are already in place, but i get same error as you! What did you do to solve it precisely?
          /RM
