    REPL via WLAN.STA server
    wlanduptermtelnet
    3 Posts 2 Posters 851 Views 3 Watching
      ljohnway
      On LoPy + PySense, trying to get REPL working over WLAN.STA, to free up UART0 for other use.
      Is there any option for e.g. os.dupterm(server) to just run REPL over WLAN?
      Work OK with os.dupterm(uart) if I only enter commands via WLAN
      Weird stuff happens on WLAN if I key commands via UART0.
      Thanks,
      John
        livius @ljohnway
        @ljohnway
        i do not remember if this is working but you can disable repl
        os.dupterm(None)
        and then simply connect to lopy throught telnet
        this should work - but i do not tested this..
        this is only concept you must test this self
          ljohnway
          Thanks.
          If I set os.dupterm(None), I get a telnet login on WLAN which works OK ('Login succeeded!), but no REPL '>>>' on WLAN (or UART0) as might be expected.
          micropython.org indicates dupterm requires a stream_object. I have tried the obvious wlan and server instances without success. What is the relevant object here?
