    Internal PCB/Metal LoRa Antennas
    antennalorapcbufl868mhz
    1 Posts 1 Posters 713 Views 1 Watching
    • joearkayJ Offline
      joearkay
      Hi all,
      This post goes alongside a previous one of my posts, regarding LoRa antennas.
      I'm interested in the successes/failures and personal experiences from using PCB/Metal Internal Antennas. I'm trying to find the best solution to use in a small batch of LoPy Temperature/Humidity sensors I am installing. All would be required to have a uFL connector for the LoPy, as well as have a small form-factor to fit inside a wall-mount enclosure.
      So far I've had a look at the following options:
      Taoglas PC81 Momopole PCB Antenna - I've been advised that Monopole is not the way to go and that these can detune (as PCB).
      Taoglas FXP280 Flex Dipole Flat Antenna - Have had mixed results with these. Have been advised that flexible antennas detune easily.
      Morava 868MHz PCB Antenna - Awaiting shipment of these for review
      ProAnt AB PRO-EB-472 Evaluation Board (Metal Antenna) - This looks ideal however is huge (about 1inch x 3inches) and uses an SMA connector instead of u.FL.
      I'd be interested in other antennas that have been used by the community, which should help me make a decision!
      From what I can see, a 'metal' antenna like the ProAnt, but mounted on a small PCB with a uFL pigtail would be ideal. I understand that these are indented to be soldered onto a final product, but there must exist a solution that meets the needs of the small runs (100 units) of LoPy-Built devices everyone is using.
      Thanks!
